Login
06-04-2012, 02:53 PM | #23 |
![]() ![]() 370
Rep 3,614
Does anyone know what sort of improvement in stopping distances this provides? Would that be for a single abrupt stop on the street, or is the main benefit fade resistance in repeated stops on a track?
See my photography at http://ronscubadiver.wordpress.com
06-04-2012, 03:03 PM | #24 | |
![]() ![]() 317
Rep 4,567
Now, is that difference worth the price? Not if I'm writing the check.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
06-04-2012, 05:01 PM | #27 | ||
![]() ![]() ![]() 451
Rep 8,430
The only other improvement is weight savings, like someone said above. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
![]() Last edited by aus; 06-04-2012 at 08:04 PM. |
06-04-2012, 08:08 PM | #29 | |||
![]() ![]() 127
Rep 4,839
Not sure if the CCM-Rs are available for the M5s yet, but they would be superior to the optional Ceramics. It would be a bit costly though.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
06-04-2012, 09:46 PM | #30 |
![]() ![]() 549
Rep 4,489
Most likely. I saw them on the M6 Coupe that was displayed at BMW of Austin; it was BMW's backup auto show car.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-05-2012, 03:50 AM | #31 | |
![]() ![]() 21
Rep 1,092
The weakest link is the tire, so upgrading any other component cannot decrease stopping distance while the grip level of the tire remains constant. As long as the brakes are strong enough to lock up the tire (which they obviously are) this will always be true. The benefits of carbon ceramic brakes are their incredible resistance to heat and fade and their light weight which improves performance (a little) and ride comfort (quite a bit). |
06-05-2012, 03:38 PM | #33 |
Rep 8,430
I'm more upset about a $100,000 car still having a sliding caliper than a delay in a carbon ceramic rotor. It's truly embarassing to still have a sliding caliper on this beast.
06-08-2012, 11:15 AM | #35 | |
![]() 112
Rep 1,419
06-08-2012, 12:15 PM | #36 |
![]() 4
Rep 139
Good that they're not available. A ridiculous option for any street car.
All you need to do with the brakes for track duty is to replace the pads with Pagid Yellows and replace the fluid with a good race fluid. If you're still driving hard enough to fade the brakes, you'll need a new set of tires after a few sessions. Ceramic brakes on a street car are noisy, expensive, fragile, and simply don't work as well as a good set of steel brakes. If you get silicone spray or Armor All on the rotors, you'll need to replace them. I don't believe there is a perceptible difference in ride quality or handling. The car's handling and ride was designed and optimized for standard steel brakes. Of course, if you've spent almost $10K on something, there's a powerful motivation to feel a number of benefits and advantages. Here's some more expert opinion: One of the EVO mag contributors, Simon George, is involved in a supercar driving experience business (www.6thgeardrivingexperienceeurope.co.uk) and wrote a piece replacing the carbon ceramic brakes with steel for a new acquisition. The quote was along the lines of 'There is no place for carbon ceramic brakes on a road car'. A brief seach turns up this exerpt from the 6th gear blog... ---quote--- Take our Lamborghini LP640 for instance. We ordered this car back in May 2007 and specifically requested it wasn’t fitted with ceramics. The reason for this is standard steel brakes are much more progressive with far better ‘feel’ than ceramics. Jump behind the wheel of a Supercar with cold ceramic brakes and attempt to stop and you could be in for a nasty shock. The steel brakes on the LP640 are superb hot or cold. So we decided to replace all our ceramic braked equipped supercars this winter with bespoke steel alternatives. ---end quote--- |
06-08-2012, 01:36 PM | #37 |
![]() 112
Rep 1,419
Yeah I know there are many downfalls to these brake systems. I would like to have them for the bling factor and for my track days (admit-tingly I am not good enough to outdo the steel brakes) but I did not know they still have the heat problem. I was under the impression that ceramic brake systems have advanced to the point where they do not have to be brought up to operating temp. Well that just saved me 8k+ I didn't know that they could be rendered useless by silicon sprays though. Why is that? Just curious...
06-08-2012, 01:55 PM | #38 | |
![]() ![]() 549
Rep 4,489
06-08-2012, 03:20 PM | #39 |
![]() 112
Rep 1,419
True but the standard m5/6 brakes fit 19s so I think the standard brakes should be considered. And you now have standard 20in rims on 911's so I wouldn't be surprised if the new M3 comes on 19's standard and 20s as an option.
