      03-01-2013, 08:23 AM   #177
bobblehead
bobblehead's Avatar
Drives: warp speed
Mine with 19" Michelin PA4. On an unplowed road, it's fine up to around 25cm. No issue at all.
Have not tried to venture out when it did snow more than 30cm (which was just last week here where I am) because don't have sufficient ground clearance
      10-30-2013, 05:35 PM   #178
CFisher
Drives: F10 M5 Black Sapphire
Digging up a somewhat old thread...but it's getting cold so here goes...
Anyone with the 408M wheel setup...is it possible to get front and rear messed up?
It's a long story but I had a shop put them on...and I notice the rear wheels *barely* clear the brake (maybe 1/8 inch) - fronts seem to have plenty of clearance. Didn't want to bother yanking one off to check if somebody already knew that clearance sounded right.
I already asked someone else with 408M's but he's not going to have an answer 'til next week and it looks like I might have a road trip before then.
      10-30-2013, 06:04 PM   #179
bobblehead
bobblehead's Avatar
Drives: warp speed
Correct -
Front alloy wheels: 19x9" ET32
Rear alloy wheels: 19x9" ET25
As you can see, the offset is different. Even though you are running the square setup.
Question: your shop put the rear to the front and front to the rear ?
      10-30-2013, 07:57 PM   #180
CFisher
Originally Posted by bobblehead View Post
Correct -
That's the thing...I'm not versed in the offset jargon...so I'm asking if that's even possible as the clearance on the rear brake is so small.
If I were close...or had the tools handy I'd check myself (the marks aren't visible right?). Thanks Bobblehead
      10-30-2013, 08:15 PM   #181
bobblehead
bobblehead's Avatar
Drives: warp speed
brake disc size is only fractional smaller...400mm for front & 396mm for rear (non ceramic brakes), the issue is more of the brake caliper.
The only way to check the proper installation is to take out the two front and see, the correct front should have BMW part # on the wheel. That being, 36112284252
Actually, you should check all four. Reason being when you bought them, the dealer may think they are all the same (19 x 9) and may have forgotten that the front & rear offset are different. Anyway, the correct rear bmw part # should read 36112284253
      10-30-2013, 09:19 PM   #182
darkrabbit
Drives: '16 F10 M5, '03 E46 M3
My M5 is FINALLY here after ED, going to pick up tomorrow at T&C BMW. I now need to get winter rims & tires for it.
I think I am going to get the 408's so I can run square with 255's.
For a tire, Blizzak LM's probably. I don't want Pirelli's and Michelin Alpins don't look aggressive enough for anything more than a light dusting (EDIT: Saw they actually work well in high depth, which is good. Just have more confidence in the LM's). Any new opinions on tires? Just want to know if there's something better I should be considering.
2018 BMW F36 440i MSport - Wife's
2016 BMW F10 M5 - Daily
2003 BMW E46 M3 - Track toy
      10-30-2013, 11:17 PM   #183
CFisher
Thanks for the info Bobblehead - I was too general in my description - caliper is definitely what I'm talking about - yankin wheels off wasn't on my to do list this week...but you're right...probably the only way i'm going to know for sure. These were a set someone traded in for other wheels and were in new condition...I just didn't freakin think before I had them mounted on the car.
Anyway...just for fun...pics of what I'm seeing...maybe it's normal and I just don't know what normal is. (The last pic is my front caliper clearance).
      10-31-2013, 01:33 AM   #184
mwlmd
mwlmd's Avatar
If you remove the wheels the offset is stamped on the inside. Don't worry about the part#. They will say ET25(Rear) or ET32(front).
F10 M5
Alpine/Sakhir/Anthracite/DCT
HRE P101. Akrapovič evolution. H&R. Bell StiR+ Laser Interceptor quad. IND cosmetics. 3M CR50.
      10-31-2013, 08:03 AM   #185
AGS
AGS's Avatar
24
Drives: 2016 F10 M5
That does not look right, I think bobblehead nailed it - your shop must have the fronts and rears swapped. I have the 408s for my winter set and when washing the wheels I can squeeze my fingers behind the rear caliprs to clean the outer portion of the barrel.
Current: 2016 Silverstone M5, 2014 Anvil WW Jeep Wrangler
Previous: 2013 Monte Carlo Blue M5 (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      10-31-2013, 09:11 PM   #186
Susoa
4 Star General
Susoa's Avatar
Drives: 2013 M5
Can't u get 4 wheels with the same offset to avoid this issue? Maybe 4 rears?
      10-31-2013, 09:21 PM   #187
Susoa
4 Star General
Susoa's Avatar
Drives: 2013 M5
Hey, what about these wheels with a 35 offset? Will they fit on all 4 corners?
TSW
Mirabeau
19X8 5-120 35MTB
for 2013 BMW M5 19"BASE F10 (TPMS)
$352.00 EA
      10-31-2013, 09:36 PM   #188
bobblehead
bobblehead's Avatar
Drives: warp speed
^ be real careful with 19", even with the right offset, they may not clear. 20" would be safer for aftermarket ones.
      11-02-2013, 11:36 AM   #189
CFisher
Sure enough...I finally got time to pull a wheel myself and they're backwards front/rear. Kicking myself for not thinking of this at the time. Guess it pays to drool over the car when its new so we notice these things - I'll have to tell my wife. Swapped them all this morning...I can sleep better now.
Thanks all for the help!
      11-02-2013, 06:26 PM   #190
bobblehead
bobblehead's Avatar
Drives: warp speed
good news. For future swap over, better mark the wheel to ensure this mistake does not happen again.
      12-03-2013, 06:41 PM   #191
deathray
Drives: F10 M5, F85 X5M, F82 M4
Same thing happened to me. A couple of the wheels looked off to me so I pulled off one them and, sure enough, it was the rear part mounted on the front passenger side (I couldnt find the offset stamp though, so, I looked it up using the part number). Even better, the wheel that they put on the front clearly has an R written on the inside of the tire.
Any word on whether this is likely to cause any damage due to the reduced brake clearance on the rear? I didnt have a spare or a stand so I couldnt change them myself. I have it back in the shop tomorrow for the swap, so, Ill report back if there's any damage found.
      12-07-2013, 05:33 AM   #192
Underwood
BMW > Audi+ Merc. Simple math.
Underwood's Avatar
Sweden
21
Drives: 14' Wrangler
This is the likely winter setup;
Stock competition package wheels, 20"
255/35 20 in front, 275/35 20 in the rear.
Handmade spiked tyres from Sweden, Lappi, complete with rally spikes if necessary.
Did I mention it's possible to get 650 spikes per tyre
Regards
H
___________________________________________
Will drive: 2016 M2
Drives: 2014 Wrangler Unlimited with goodies
Drove: 2014 M5 Competition Package, 2012 1M, 2010 GT-R
      12-07-2013, 11:26 AM   #193
mwlmd
mwlmd's Avatar
I hope you never plan to drive on anything but snow and ice with those. Yikes! This sounds like overkill dipped in paranoia!!!
But do post pics. I want to see an M5 with these tires mounted!!
F10 M5
      12-09-2013, 07:48 AM   #194
Underwood
Underwood's Avatar
Sweden
21
This car runs on Lappi tires, the same ones I'm thinking of.
But I think now I may go with Nokian Hakkapeliitta 8 instead.
They receive so many positive reviews its impossible to ignore.
      12-09-2013, 12:40 PM   #195
mwlmd
mwlmd's Avatar
Cool video. That ski slope must be super hard pack? I am amazed the car doesn't sink at all when stopped. Also, It would seem to me that if you want all out winter performance perhaps an awe car would be better? RS6 or such?
Also, it appears according their product info that those tires used in the video are for competition use only and not approved for street use. Is that true?
F10 M5
      12-09-2013, 09:31 PM   #196
remmib
remmib's Avatar
Norway
828
Drives: 2013 F10 520d M-Sport
Are those road legal?
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      12-10-2013, 10:11 AM   #197
Poleposition
Poleposition's Avatar
Drives: very well
Tires like that would be torn up on a dry road in no time.
2016 Individual M5
Frozen Gray/Sakhir/Aluminum
2015 F86 X6M
2015 i3-REX
- 2012 Wrangler Unlimited
IG @kerrysbr
      12-10-2013, 12:14 PM   #198
DrewM5
Drives: SG E60 M5
I am shopping winter tires right now to mount on the 601M wheels (20 inch). I don't drive the car in the snow at all, but can't run high performance summer tires in winter in NY. I prefer to stay with a staggered set - giving the BMW engineers some credit for their design. Nobody seems to make winters in the stock sizes. Tirerack was suggesting Sottozero Serie II in 295/30/20 rear and 245/35/20 front (supposedly the 911 fitment). They also have the regular Sottozero in 285/30/20 rear and 255/35/20 front.
Seems to me that it would make more sense to go 10mm narrower both front and back rather than stay stock in backand go 20mm narrower up front. Also, the Sottozero get better survey responses than the Stoozero Serie II.
Thoughts?
2013 m5 winter tires, 2013 m5 winter wheels, 2014 m5 winter tires, 2014 m5 winter wheels, bmw m5 winter tires, bmw m5 winter wheels, f10 m5 winter tires, f10 m5 winter wheels, m5 winter tires, m5 winter wheels, winter tires f10 m5, winter wheels f10 m5
