      10-16-2012, 11:49 PM   #1
mgallen
Member
Drives: 2013 M5 Azurite Black
Water De-ionizer - Is it worth it?
Does anyone have any experience using a de-ionized water system to rinse your car in order to avoid water spots? I've read conflicting opinions on its effectiveness.
I'm leaning against making the investment, but wanted to hear from others with experience.
      10-17-2012, 08:40 AM   #2
AGS
AGS's Avatar
32
Drives: 2016 F10 M5
I bought this CRSpotless system:
http://www.crspotless.com/de-ionizin...ed-system.html
If I had it to do over again, not sure I would spend the $300. Half the time I end up drying the car off anyway because I need to drive somewhere and I don't want road dust getting picked up by the residual water on the car. If you have the time to let the car sit for a couple hours after you wash it then it may save you 15 to 20 minutes of drying time.
Current: 2016 Silverstone M5, 2014 Anvil WW Jeep Wrangler
Previous: 2013 Monte Carlo Blue M5 (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      10-17-2012, 09:03 AM   #3
The trick is to combine this with a blower so you have the car mostly dry but don't need a towel.
2014 Porsche 911 Turbo S
2018 Mercedes-AMG E63S 4MATIC+
      10-17-2012, 11:55 AM   #4
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [3.88]
A water deionizer like CR Spotless is actually the primary item I recommend to clients after I've corrected their paint. Removing the drying stage from a maintenance wash is one of the best ways to avoid swirls, as most people swirl their car during drying. I've written a bit about how important 0 PPM water is on my FAQ (look near the bottom):
http://eclipsisna.com/?ena=faq
The car doesn't need to sit for several hours to dry if you're using 0 PPM water. If you let the car dry under the sun, 15 minutes of drying time should suffice.
      10-17-2012, 10:04 PM   #5
mgallen
Member
Thanks for the insight. I read your website, and you recommend a 3-step process (water softener, reverse osmosis, then DI water). The CR Spotless is DI water only, so do I need to also buy the water softener and reverse osmosis system in order to get spot-free water? Seems like a lot of steps.
      10-18-2012, 07:19 PM   #6
eclipsisNA
The 3-step filtration is for efficiency. You can get spot free water w/ a RO system or DI system on their own, but when you combine each of them, each offers something that the others don't. For someone like me that details a lot of cars, the cost is worth it, but I think for the average user, it's overkill. Stick to CR Spotless, it's more than worth the cost.
      10-18-2012, 09:59 PM   #7
mgallen
Member
Excellent. Thanks for the advice.
