Reply
      12-06-2012, 02:52 PM   #23
Used2be
Perennial PFC
Used2be's Avatar
Drives: F10 M5 SpaceGray/SO
Electrical connector design
Originally Posted by Nate@IND View Post
We also just started a core program where we ship the door handle set pre painted.
I don't have my car yet, but from all the pictures I've seen of any part with an electrical connection on it, they are really beautifully designed, the electrical connections I mean. The BMW motorcycles are built the same, and for you lucky others who might happen to also own a Mercedes or Audi, are theirs put together the same way? I wonder if BMW contracts with a major supplier, in Germany probably, who supplies others, or is it an in-house company? Anybody privy to that info?
Used2be is offline   United_States
      12-06-2012, 05:07 PM   #24
M54ccibo
M54ccibo's Avatar
Drives: '13 F10 M5 AW/SO
The first cores are going out today. I'll have a thread up today so that we can start the list. AW would be no problem at all.
Sweet! PM me a quote...AW please!
M54ccibo is offline   United_States
      12-06-2012, 05:59 PM   #25
Nate@IND
Nate@IND's Avatar
two cores already shipped.
http://f10.m5post.com/forums/showthr...7#post13114437
Nate@IND is offline   Reply With Quote
      12-06-2012, 09:32 PM   #26
Grayblack
Grayblack's Avatar
Drives: M5 F10 SG
Do you have a DIY?
Grayblack is offline   Reply With Quote
      12-06-2012, 10:22 PM   #27
mgallen
Member
Drives: 2013 M5 Azurite Black
Originally Posted by jmh View Post
Yup. I'm in Boston on a regular basis. Often multiple times a week (usually in the Fortpoint area)
Thanks JMH for the recommendations. I just got my car detailed today by Rick Nelson at Unique Car Care in Wakefield, MA.
I got a complete detail inside and outside, Opti-Coat 2.0, and XPel clear bra (full hood, bumper, side fenders, and mirrors).
The car looks fantastic! I highly recommend Rick and his team to anyone looking for a high quality detailer.
mgallen is offline   United_States
      12-13-2012, 10:42 AM   #28
jmh
Internet Crash Test Dummy
jmh's Avatar
Drives: F10/E92 335xi
For those interested in having their door handles wrapped with gloss vinyl
for those in the Boston/New England area I had mine done by my local
BMW dealer (great body shop) and they charged ~160$
13 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / Color matched side and front grills (lightly tinted LEDs) / Akrapovic Evolution Exhaust / Hartge Springs / HRE S107
jmh is offline   United_States
      12-13-2012, 12:08 PM   #29
Nate@IND
Nate@IND's Avatar
Originally Posted by Grayblack View Post
Do you have a DIY?
Here you go
Originally Posted by Andrew@IND View Post
Tools used:
  • Torx15 x 18" driver
  • Nylon prybar
  • Flashlight
The first step is removing the rubber plug located on the door jamb portion of the door panel. Removing this plug enables access to the Torx15 bolt that secures the handle assembly in place. Remove the plug using your fingers or a nylon trim removal tool.
Now that the rubber piece is removed take a quick peek with a flashlight and locate the position of the T15 screw. Although our technician used a 18" long driver you can get by with a standard 7.5" tool. Simply remove the screw and move on to step number 3.
The T15 screw is the only major component securing the handle assembly to the door. The only other area secured to the door is the front portion of the handle. Now with light pressure pull the handle toward you as if you were opening the door.
As you begin to pull the handle you will notice the front portion of the handle is secured to the door via a 2 pin connector. These connectors are removed by unlatching the plastic tab on each pin. For this step our technician used a angled pick, but this step allows for some improvisation.
Now that the 2 pin connector you can safely remove the handle from the door.
Installation is simply the reverse procedure, but please note that while the handle is removed the door will not properly latch. Do not close the door while the handles are not attached to the car.
      12-13-2012, 01:03 PM   #30
LAKEOM5
LAKEOM5's Avatar
Drives: 2013 M5 Black Sapphire
I like it both ways. I have a black met and the chrome is a nice relief from the all black. I did install IND gloss black kidneys and side grills because the stock car is too chromey for my tastes.
On a white I say wrap them black.
LAKEOM5 is offline   United_States
      12-13-2012, 03:19 PM   #31
mwlmd
mwlmd's Avatar
Darn it!!! I was planning to get them painted alpine white!
E90 M3 (gone but not forgotten)
Jerez/Fox/Aluminum/6MT
F10 M5
Alpine/Sakhir/Anthracite/DCT
mwlmd is offline   United_States
      12-13-2012, 06:46 PM   #32
LAKEOM5
LAKEOM5's Avatar
Lol. You can do that too. Looks good either way.
Actually white would look pretty tight. Just make sure your tint isn't full of bubbles and your clear bra isn't peeling off.
Then you are good to go.
Reply
Forum Jump
