Reply
      11-02-2012, 06:21 PM   #1
Lizard1
Break-In Service Questions
What is exactly included in the break-in service? I called my service advisor and asked for an appt for the break-in service. He had NO idea what I was talking about. It took about 5minutes of nearly begging him to just give me an appt. Finally he said just drop it off next Friday and they'd get in taken care of. Unfortunately this is the only BMW dealer within 5hrs. Sales is great - love the guys - but service is pretty ridiculous.
So I'd like a list to be able to verify that they have done everything. Thanks for any help!
Lizard1 is offline
      11-02-2012, 07:09 PM   #2
efm9821
efm9821's Avatar
Drives: F10 M5, E46 M3
2013 M5  [0.00]
I had my F10 M5's 1200 mile service performed in BMW Niederlassung Munich while on ED, reportedly one of the best and most knowledgable service shops in Germany. They changed the oil, no gear box, no differential service. Some postings you'll find in this forum states they had gear box/diff services as well ...
efm9821 is offline   United_States
      11-02-2012, 07:18 PM   #3
DoctaM3
500+ HP Club
DoctaM3's Avatar
Drives: Silver Gray Metallic X6M & M6
I got mine done while on ED as well. By definition, they should have changed your differential oil and well as engine oil.
DoctaM3 is offline   United_States
      11-02-2012, 07:25 PM   #4
Rob///M5
Rob///M5's Avatar
Drives: 2013 M5 SSII
2013 BMW M5  [5.00]
Yes, this is what was done on my car.
Rob///M5 is offline   Reply With Quote
      11-02-2012, 07:30 PM   #5
mdernst
mdernst's Avatar
Drives: 2013 M5
2013 BMW M5  [0.00]
Break in check service
The 1,200 mile service on the F10 M5 is:
Change engine oil and filter
Change differential oil
Change transmission oil (6 spd manual only - no service to DCT)
The attached .pdf is straight from the BMW TIS. If anything else was/wasn't done then they didn't do it right.
Mike
Current: 2013 BMW M5
Previous: 2012 A7; 2011 S5; 2011 X5M; 2010 750Li; 2009 M3; 2008 X5; 2003 M5; 1998 540i 6 spd.
mdernst is offline   United_States
      11-02-2012, 08:00 PM   #6
nybimmerfan
nybimmerfan's Avatar
Drives: 2013 MCB M5
I did ED and made 2000+ miles but did not have any break-in service thinking of having it done when the car gets to the U.S. I am having the car redelivered to the Performance Center in South Carolina. Should I schedule a break-in service for the car or is this automatically done when it gets to the PC since the car would clearly indicate that no break-in service has been performed yet?
nybimmerfan is offline   United_States
      11-02-2012, 08:00 PM   #7
jphughan
jphughan's Avatar
Drives: 2011.75 M3 E92 6MT
It should be:
- Engine oil
- Differential oil
- Gearbox oil ONLY if 6MT; DCT is "lifetime"
- Disable "break-in mode", which for the first time on the M5 is a special ECU mode.
For engine oil, make sure they don't use the 10W-60 oil that almost all other M cars have always used. Since it sounds like this dealership doesn't know what they're talking about, you should stress this. The X5M, X6M, 1M, and now the M5 all use I believe 0W-30. Verify that exact viscosity in your owner's manual and make absolutely certain that you don't get a tech who says, "It's an M car, so it must use 10W-60."
11 M3 E92 Le Mans | Black Nov w/ Alum | 6MT | Premium 2 | Convenience | 19" | EDC | Prem Audio | Moonroof | BMW Apps | Vorshlag Adjustable Camber Plates | StopTech Street Perf Pads | Castrol SRF Fluid | ModMyNav.com rear camera
jphughan is offline   United_States
      11-02-2012, 09:30 PM   #8
efm9821
efm9821's Avatar
2013 M5  [0.00]
Mike
Excellent, thanks for providing the TIS! I've had my concerns and planned to have my local dealership review the records. This helps!
      11-02-2012, 10:22 PM   #9
Rob///M5
Rob///M5's Avatar
2013 BMW M5  [5.00]
Originally Posted by jphughan
It should be:
- Engine oil
- Differential oil
In the US BMW service will probably use 5W30, which is acceptable.
      11-02-2012, 11:04 PM   #10
SpotM5
SpotM5's Avatar
Drives: 2013 BMW M5
agree, engine oil, diff (for dct)
SpotM5 is offline   Reply With Quote
      11-03-2012, 09:56 AM   #11
thebishman
You need to get the diff oil changed ASAP
Bish
thebishman is offline   Reply With Quote
      11-03-2012, 09:58 AM   #12
Niko1414
Drives: 2013 M5 & 2009 C63-Tune
It should be:
- Engine oil
- Differential oil
Exactly that's what they used on mine. 5W30
Niko1414 is offline   United_States
      11-04-2012, 06:23 PM   #13
Racer Louis
Drives: 2013 M5
I've done business with BMW Niederlassung in the past and you're right, the service is top-notch. But then again, it should be -- it is owned by BMW AG!
Before the Welt that's where ED cars were delivered.
Racer Louis is offline   United_States
Reply
Forum Jump
