Reply
      12-26-2012, 03:00 PM   #45
Aussie F10M
Aussie F10M's Avatar
I just used a wide flat head screwdriver and very gently pried out the whole assembly to replace the bulbs from behind. No instructions - I just used the force ....
Current: Singapore Grey 2012 M5
Aussie F10M is offline   Australia
      12-26-2012, 08:23 PM   #46
MCM5
MCM5's Avatar
Drives: MCB F10 M5
I used quite a bit of force too, but didn't work. Did you start prying it out from the front or rear end of the assembly?
MCM5 is offline   Reply With Quote
      12-26-2012, 08:28 PM   #47
Grayblack
Grayblack's Avatar
Drives: M5 F10 SG
I used a credit card to pry off the front of the housing.
Originally Posted by MCM5 View Post
just did the installation. everything was good except the rear overhead. I followed ECS instructions but just couldn't get the housing off from the headliner. any tips or tricks to go around this?
Grayblack is offline   Reply With Quote
      12-27-2012, 12:02 AM   #48
MCM5
MCM5's Avatar
Drives: MCB F10 M5
Actually, I ordered the tool set from ECS as well.
I will give it another try with credit card. Thanks.
      12-27-2012, 11:46 PM   #49
MCM5
MCM5's Avatar
Drives: MCB F10 M5
BTW, has anyone changed the reverse light to LED (with built-in resistor to avoid error warning) ?
I've seen such aftermarket LEDs but most will trigger the error, & require additional wiring with resistor).
      01-07-2013, 08:27 PM   #50
Rob///M5
Rob///M5's Avatar
Drives: 2013 M5 SSII
2013 BMW M5  [5.00]
Did the ECS install - super easy and makes the car look so much more modern. It's perhaps a tiny bit blue for my taste, but a huge improvement over the ancient looking yellow/brown color.
The pic in the front is with LED (perfect match to Silverstone leather and aluminum trim).
The second pic is with stock lighting in the rear dome.
Rob///M5 is offline   Reply With Quote
      01-08-2013, 01:30 AM   #51
Aussie F10M
Sorry for the late reply. I just used a wide flat head screw driver from the front of the panel.
      01-08-2013, 01:42 AM   #52
MCM5
MCM5's Avatar
Drives: MCB F10 M5
After trying many times, I still couldn't get it out.
At the rear of my car, the overhead lights are 1 main + 2 reading. Is yours the same ?
Guess the assembly may be different for different country versions.
      02-21-2013, 01:05 PM   #53
E92-Lighting
PM me for the quickest response, less than 2 days
E92-Lighting's Avatar
Drives: 2012 E92 LCI AW Msport + PPK1
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
we have the brightest F10 LED interior kits in the world, here is our full replacement piece.
E92-Lighting is offline   United_States
      02-21-2013, 04:45 PM   #54
Rob///M5
Rob///M5's Avatar
2013 BMW M5  [5.00]
"Brightest" is not exactly a selling point in my mind. "Aesthetically pleasing" is much more appropriate for the M5 crowd.
      02-21-2013, 08:06 PM   #55
ColdList
Drives: 2013 Silverstone F10 M5 DCT
+1. Man did that promotion come off "cheap".
ColdList is offline   Reply With Quote
Reply
Forum Jump
