      02-11-2013, 02:19 AM   #23
chudak18
chudak18's Avatar
Drives: E92 335, W463 G55
Originally Posted by BikeGeek View Post
Took us about 5.5 hours in my garage Saturday. Your write-up was great guidance.
Good to hear. Wish I had this reference, took me seven hours, mainly bc I had to figure out the rear deck disassembly. Lol pain in the buttox.
      03-25-2013, 02:07 PM   #24
akh23456
All I do is Win... Eat Race Sleep
akh23456's Avatar
Drives: RS7, X5M coming soon
2017 X5M  [0.00]
2015 rs7  [0.00]
2009 M3  [4.28]
2013 f10 M5  [0.00]
i think i am going to have to come to your shop for this.
Rs7 : 10.624 131.50 with a 1.7 60ft Toyo R888
F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires
E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires
      04-14-2013, 04:08 PM   #25
Boss330
Boss330's Avatar
Norway
855
For the rear springs I have seen another write up where they just removed the rear shelf speakers. Pop out the cover and then the speaker itself and you have access to the bolts that attach the strut to the body.
http://f10.5post.com/forums/showthread.php?t=628336
Someone also mentioned that this was the method used by a professional mechanic when doing this job on a F10.
From your exerience, would this be easier than removing the shelf altogether?
      05-01-2013, 08:02 AM   #26
Boss330
Boss330's Avatar
Norway
855
I just changed springs on my car (Eibach ProKit), a few things that I noticed:
Access to the rear strut mounting bolts is really easy through the speaker holes in the rear shelf. Just pop out the speaker covers and unbolt the speakers and the strut bolts are readily accessible.
Using a small telescopic jack instead of a prybar to press the suspension down eased up the strut removal process immensely (after the struts have been unbolted).
I did this both front and rear. In the front I was able to "jack down" the suspension so that the lower strut cleared the lower A-arm and the strut came out real easy.
Same in the rear, which also meant that I did not have to unbolt any other parts than the strut itself.
I actually found the rears to be the easiest and least labour intensive part of the job.
Really easy job apart from the spring compressor tool that I used which was an endless wrench turning excercise...
      05-03-2013, 10:10 PM   #27
hawaiiracer1
hawaiiracer1's Avatar
32
Drives: 2013 M5, 2008 M3, 2009 M3,991
Great write up and I just had my M5 done from the guys here in the Bay Area took about 4 hours but they've done a few and I gotta say it was a job we'll Done. Sonic MS
      03-28-2014, 06:28 PM   #28
Day Laborer
Day Laborer's Avatar
257
Drives: F10 M5 / F87 M2 / F82 M4 GTS
What socket size for the point nut to remove the springs from the strut?
http://www.precisionmedals.com/charts1/car.jpg
      07-11-2014, 11:49 AM   #29
harry007
Drives: White M5 F10
Hi hope everyone is well. I have just had my M5 lowered and have struck a problem with the head lights. The sensors on the arms have been checked but no joy. The head light beam is simply leaning lower to the ground and will not light up the road. Im stuck. What do I do?
Will BMW look at it under warranty?
how else can the head lights be adjusted?
is this a natural cause because of the lowering?
Any help/ advice would be appreciated. Thanks
      10-11-2015, 05:36 PM   #30
Skeeter_f10
Drives: f10 m5
I know this is old but just wanted to say thanks for this write up. Helped a lot doing my kwv3 install.
      01-09-2016, 12:28 PM   #31
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
This should apply to 2013 550 wouldn't you say?
      01-09-2016, 12:36 PM   #32
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Not sure if you got this issue resolved I think you might have Adaptive Headlight controller issue.
      03-24-2016, 09:20 AM   #33
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
AWESOME! I've been looking and this along with the other link posted from hamandcheese is very helpful as i'll be tackling on my KWV1 coilover install. BTW, any torque settings on any of the bolts when putting them back on?
~CinnamonLeatherInterior~21"3Piece AlphaForgedWheels~BMSgoldTitaniumLugz~ 3dCarbonRearSpoiler~3dCarbonFrontLip~3dCarbonSideS kirtExtensions~DTMCarbonDiffuser~CarbonWrapPUFront Splitter~CarbonRearSplitters~PUrearDiffuserTray~
~CarbonEmblems~LedermanzWheel~ShadowlineKit~Double SlatGrills~WstyleCarbonRoofSpoiler~CarbonMirrorCov ers~MeisterschaftEVC90mmQuadExhaust~CarbonTipCover s~KWV1Coilovers~MStylePedals~G2GoldCalipers~35%Tin T~
      05-23-2016, 04:35 PM   #34
tidal k
tidal k's Avatar
Drives: f01 750i
Excellent write up... Essentially identical to the F01 install.. minus the EDC plugs on top..
I hated life doing the rear... but unfortunately... I think I have a pinched wire somewhere... "EDC malf."
Clean car man!!
      06-21-2016, 09:40 PM   #35
TrevorM3
Drives: 6.3 AMG
will be using this soon. wonder if op is still around this board..
      06-22-2016, 09:54 PM   #36
M5Beast_NYC
Drives: 15 M5
Question about the rear strut assembly, if you don't/shouldn't remove the wire from the top bolt, how do you get the nut out and eventually the top hat to get the spring off?
      08-24-2016, 03:03 AM   #37
clubcsl
clubcsl's Avatar
Drives: M3 CSL,M5 F10,Z4 35is
Do we know the socket size needed now ?
www.clubcsl.com - I am a BMW Motorsport fan !
      08-31-2016, 04:51 PM   #38
clubcsl
clubcsl's Avatar
It is 18.
      09-01-2016, 03:54 AM   #39
ur20v
When hanging the front springs becareful to align the top mount with the plasti spring purch, theres an arrow on each- if you don't it will all go together but the 3 bolts that hold the purch have now where to go.
Otherwise its an easy job - just over an hour and I had both sides buttoned up and H&R's installed. Next I will do the back although I am happy with the raked stance.
      05-19-2017, 06:37 AM   #40
laroldino
laroldino's Avatar
Drives: M5 F10 2013
i wish this still had the pictures as i was going to attempt this myself.
Current car - BMW M5 F10 - Silverstone II
Previous cars:-
Golf R - stage 2 400 hp - in the best colour lapiz
Mini Cooper JCW - Blue
BMW 135i N54 - black - Jb4'd
      12-28-2017, 01:36 PM   #41
BMWfan95
Drives: BMW M5 F10
same
2013 BMW M5 Silverstone Metallic/ Black Interior
Executive Package - Driver Assistance Package- Bang and Olufsen
      01-01-2018, 07:44 AM   #42
laroldino
laroldino's Avatar
Drives: M5 F10 2013
wish the pictures were still on here as i can't see them, was going to do it in a couple of weeks.. weep weep.
Previous cars:-
