Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
      01-09-2013, 06:18 PM   #23
singularity
Driver
singularity's Avatar
59
Drives: M5 (F10)
That's a factory defect which BMW said could have a bad effect on performance. The problem of a 'whistle' sound when under throttle also disappeared after this got fixed. I've mentioned it several times already, but nobody read it it seems.
You guys should all take your cars to your service and have those holes covered with the replacement from BMW.
Why those holes were made in the first place and why exactly it was a recall is beyond me.
      01-09-2013, 07:39 PM   #24
Warehouser
Warehouser's Avatar
Drives: 16 X5M - LBB
Just checked mine, I have those plates on both boxes...
      01-09-2013, 07:54 PM   #25
Rob///M5
Rob///M5's Avatar
36
Drives: 2013 M5 SSII
2013 BMW M5  [5.00]
Is there a way to check without removing them? I plugged my VIN into the recall website, but shows nothing for my car.
      01-09-2013, 11:34 PM   #26
MCM5
MCM5's Avatar
Drives: MCB F10 M5
I've been hearing the 'whistle' sound but thought it's normal. Will check mine & talk to bmw when i have 1st service 2 weeks later.
+1
      01-10-2013, 12:21 AM   #27
Warehouser
Warehouser's Avatar
You don't have to remove the whole box, just the top as if cleaning or replacing the filter. 6-7 torx screws, lift the filter and you can see inside.
      01-10-2013, 12:49 AM   #28
Niko1414
Drives: 650s, s550, e93 M3, 997GT3RS
How do you get to that back corner screw ??? The angle looks too tight ?
      01-10-2013, 03:13 AM   #29
MasterDank
Boats & Hoes
MasterDank's Avatar
Drives: 13 F10 M5 Sakhir Orang,Chohiba
Originally Posted by Fly M5 View Post
This is my opinion only. My production date was 7/12/12 and was not part of the recall. I believe mine was the first few batches that came in along with member MasterDank.
I have checked with my friends that have taken delivery in the last few months and
they all have the plate..so far 3 different cars.
That intrigues me.... Ill check my fathers M6 and friends M5 that are both months newer then mine.
Aloha
Alex
Change is inevitable Progress Is optional
      01-10-2013, 09:02 AM   #30
Charlie Brown
Charlie Brown's Avatar
Drives: F10 M5 Azurite Black
My production date was after the oil pump recall. I'll check mine this weekend and post up.
I'm wondering though. Assuming the holes were engineered into the original production they must have served a purpose that later was determined less desirable than the purpose and expense of installing block off plates. Do you think a performance engineer designed the holes to ensure sufficient air volume at WOT but later a sound engineer determined the whistle was undesirable and BMW decided that customers would complain about the noise in every day driving while not noticing a slight decrease in performance at WOT?
      01-10-2013, 09:11 AM   #31
bobblehead
bobblehead's Avatar
Drives: warp speed
^ that's a very good point
      01-10-2013, 09:47 AM   #32
nyamg
nyamg's Avatar
Drives: Porsche 997 Turbo
interesting theory????
2015 991 GT3
2013 M5
2014 LEXUS LX570
2014 GMC SIERRA
      01-10-2013, 09:55 AM   #33
Poleposition
Poleposition's Avatar
Drives: very well
So how do we know definitively if they should or shouldnt be there?
2016 Individual M5
Frozen Gray/Sakhir/Aluminum
2015 F86 X6M
2015 i3-REX
- 2012 Wrangler Unlimited
IG @kerrysbr
      01-10-2013, 09:59 AM   #34
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
I will check my M6 airbox's as well and report back.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread:
http://www.6post.com/forums/showthread.php?t=794659
      01-12-2013, 06:30 PM   #35
Charlie Brown
I have the plates blocking the holes.
      01-12-2013, 07:08 PM   #36
SANguru
Drives: i8, X5 50,M550i,Tesla, MP4-12c
the only thing that will affect performance is hot air. More air/cooler air/ram air is always the goal of any intake. An open hole on the bottle of an airbox given that it is away from the engine is actually better for performance. The only draw back for something like that might be heavy rain or whistling but you guys are debating over something not very important..
      01-14-2013, 12:11 PM   #37
There is no recall in the US. Did you notice any performance change after you closed the holes?
2014 Porsche 911 Turbo S
2018 Mercedes-AMG E63S 4MATIC+
2015 Mercedes-Benz C300 4MATIC
      01-14-2013, 05:54 PM   #38
Fly M5
Drives: 2014 M6GC CP & 2015 M3
Still waiting to hear back from dealer
Current: 2014 M6GC CP and 2015 M3
Past: 2013 M5, 2012 E63, 2011 panamera turbo, 2010 E63, 2010 GTR, 2009 C63, 2008 M5
      01-16-2013, 03:24 PM   #39
Surely it can't be completely trivial? If it was then why would BMW go to the expense of changing the design?
      01-28-2013, 11:55 AM   #40
MCM5
MCM5's Avatar
Drives: MCB F10 M5
Had BMW check on this during my 1st service today. Mine had open holes at the bottom, & they said it's supposed to be like that, meaning they're not gonna do anything about it.
      01-28-2013, 05:32 PM   #41
Fly M5
quote from my dealer: . He said the answer he got from Germany is that this is a running production change and that there is no positive or negative effect on the way the car runs. They reassured me that no difference should be felt between a car with it and a car with out.
He also said the block off plate parts are available and will let me know when they arrive.
      01-28-2013, 05:35 PM   #42
Fly M5
I'm going to dyno my car before and after just for to see the results.
      01-28-2013, 06:07 PM   #43
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Just opened mine up, and the plates are there. Mine is 2013, Week 35 build. Were the EARLY build cars the only ones without plates?
Here is another question. The E60 had charcoal filters. I was interested in seeing if the F10 did as well. Sure enough, this car has them. Us E60 guys all removed our charcoal filters on the upper half of the airbox. Pain in the butt, on the F10 they are WAY easier to remove (just snap out). With the E60, if I remember correctly, only the North American cars had them. Can any of the european members confirm/deny that they have the charcoal filters?
Thinking about taking them out and going for a couple quick spins. Shouldn't cause any issues, as all we are doing is removing another restriction. Anyone else do this?
Current: '16 GT4
Past ///Ms:
'10 E60 M5, Space Gray/Black
      01-28-2013, 11:55 PM   #44
MCM5
MCM5's Avatar
Drives: MCB F10 M5
Pls share the parts number for the block off plate if available. Want to check it with the local dealer here.
Interested to know the result.
