      03-16-2013, 05:53 PM   #1
acedaking
Drives: 08 M5, 10 M6, 13 M5, 14' M6-CP
Needing oil
Hey guys
I picked up my M5 on sept 15th, i drove about 1300 miles within the first 2 weeks, took a couple of road trips.. since then i have put on an additional 2700 miles on the car for a total of 4000 miles to date.. I travel alot so sometimes the car sits for weeks at at time.. but i have had to add oil about 4 times already, is this normal?
i've had a couple of m3's, a 2008 m5 and a 2010 m6.. none of them drank oil like this.. should i be concerned. BTW my car was affected by the oil pump recall
      03-16-2013, 05:58 PM   #2
AGS
AGS's Avatar
32
Drives: 2016 F10 M5
That seems on the high side. I'm at about 6,000 miles and have only added one quart since the break-in service.
      03-16-2013, 06:01 PM   #3
Tylerstar
Tylerstar's Avatar
42
Theres like 5 different threads on this topic.
http://f10.m5post.com/forums/forumdisplay.php?f=435
      03-16-2013, 07:45 PM   #4
Bokke
Bokke's Avatar
Drives: E90 M3 / F82 M4 / 991 GT3
Sounds like me; I actually ended up with a defective oil filler cap seal, so I had a small leak and improper venting.
Although, checking the oil level last night I bet I have to add my 4 quart since I got her; I am currently at 4,5xx miles.
I am hoping this settles down.....
Garage:
09 E90 ///M3 | SS | Black | Modded
13 Cayenne GTS | Carmine Red
15 F10 ///M5 | Frozen Black | CP | SO Interior | Piano Black
18 991.2 GT3 | Carmine Red | PCCB | LWB
      03-16-2013, 08:15 PM   #5
h4nh
h4nh's Avatar
Drives: 09 SC E90 M3 / 13 F10 M5
2009 E90 M3 (superc ...  [5.00]
2013 M5  [0.00]
I've been putting a quart every 1500- 2000 miles I guess it's secretly a 2 stroke and requires oil / gas.
      03-16-2013, 10:38 PM   #6
cmhsam
Drives: 2013 F10 M5
Originally Posted by acedaking
Hey guys
I am in the same boat. Had to go to the dealer four times for oil. Just under 5k miles. I too am concerned about the oil consumption.
      03-16-2013, 10:55 PM   #7
BarryB
Drives: 30Jahre M5 plus a few more M's
Added 2x in 6k. Drive aggressively too.....
F10 30 Jahre M5/F80 30 Jahre M3
F82 M4 GTS/ E39 S3 M5
E36 M3 with S54 Swap/F22 M235 Dinan Stage 4
F85 X5M 3.5i/03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)[b]
      03-21-2013, 07:41 PM   #8
acedaking
I have only driven the car aggressively once, which is recently.. and when i say aggressive - its not even really aggressive, I may have shifted at about 7200 when shifting from 1st to 2nd a few times .. the very next time i drove the car which was about a week later the "minimum oil level" shit comes up on the screen..
i dont understand why the car always needs oil
      03-21-2013, 07:42 PM   #9
acedaking
you are in ny right? going to the meet at floyd bennett field on sat?
      03-21-2013, 07:43 PM   #10
acedaking
how did you find out you had a defective oil filler cap seal?
      03-21-2013, 08:02 PM   #11
Bokke
Bokke's Avatar
Took it to the dealer.....
Garage:
      03-21-2013, 08:08 PM   #12
acedaking
thanks- Ill make an appt.
      03-23-2013, 09:33 AM   #13
cmhsam
Drives: 2013 F10 M5
I will be making another appt as well. I just got it for the fifth time in 5K miles
      06-07-2013, 09:21 AM   #14
maem2501
maem2501's Avatar
Drives: 2013 Alpine White M5
SI B11 03 13
Engine May 2013
Technical Service
This Service Information bulletin replaces SI B11 05 84 dated March 1985.
SUBJECT
Engine Oil Consumption
MODEL
All
information
All engines normally consume a certain amount of engine oil. This is necessary in order to properly lubricate the cylinder walls, pistons, piston rings, valves and turbocharger(s), if equipped.
In addition, engines with less than 6,000 miles will generally consume additional engine oil because the internal engine components are not fully seated (break-in). Therefore, engine oil consumption complaints received prior to 6,000 miles cannot be considered.
Once a new or remanufactured engine has accumulated 6,000 miles, oil consumption can be considered if there is a drastic change in the engine oil consumption rate (e.g., the engine oil consumption rate triples) under similar driving conditions.
Engines equipped with a turbocharger(s) will consume more engine oil than normally aspirated engines (non-turbocharged). The additional oil that is consumed in a turbocharged engine is mainly due to the turbocharger lubrication requirements. Some of the engine oil normally migrates past the turbocharger turbine bearing seals and will enter the intake tract of the engine. All turbocharged engines also require a complex crankcase ventilation system. The crankcase ventilation system needs to maintain a small vacuum on the crankcase and not allow the crankcase to be pressurized.
Pressurizing the engine crankcase can lead to external engine oil leaks and increased engine oil consumption via the piston rings and valve seals. When the load and the boost level of a turbocharged engine is varied, the path of the crankcase pressure is changed. During the crankcase ventilation path transition, a small amount of engine oil will pass through the crankcase ventilation system and is additionally consumed. The additional engine oil consumption of a turbocharged engine, as compared to a normally aspirated engine, is normal and not a defect.
oil consumption specification
All BMW engines (excluding Motorsport) can consume up to 1 quart of engine oil per 750 miles at any time.
Due to the increased engine power, all Motorsport engines can consume up to 2.5 quarts of engine oil per 1,000 miles at any time.
diagnostic hints
When an oil consumption complaint is received, it may be possible to correct it without performing extensive engine repairs. Check the following frequent causes of excessive oil consumption prior to undertaking any engine consumption analysis or repairs. Submit a PuMA case for assistance.
Proper Maintenance
Has the vehicle received proper maintenance? Certain external conditions (mainly city driving style and/or high engine loads; poor fuel quality; and extreme ambient temperatures), combined with excessively long oil service intervals, may accelerate engine oil degradation, which may cause premature wear of the engine components. Continuous city driving (stop-and-go traffic); fuels with high olefin content; sulfur and certain aromatic fractions; and very high ambient temperatures are the most influential factors causing premature oil aging and consecutive engine mechanical deterioration.
External Leakage
The engine should be leak-free before starting any engine oil consumption analysis.
Overfilling
If the oil level is too high, oil in the crankcase will be thrown against the cylinder walls and consumed. Check the dipstick markings or electronic measurement (as equipped) to be sure of accuracy. The oil level must not be higher than the upper mark.
Engine Oil Viscosity/Quality
The use of oil with the wrong viscosity rating for operating conditions can cause high oil consumption. Check the Owner's Manual to determine the proper viscosity for prevailing conditions.
Engine Speed and Load
If vehicle operating conditions are severe, oil consumption will be higher than normal. Extreme load or continuous high engine speed will result in increased oil consumption.
Crankcase Ventilation
The crankcase ventilation systems use various different crankcase ventilation valves, depending on the engine type. Although the valves all look different, they function similarly, using a spring and diaphragm assembly to control the crankcase pressure. A properly functioning pressure control valve is designed to maintain a slight vacuum (under-pressure) in the crankcase, which assures reliable crankcase venting during all engine operating conditions. One of the results of a malfunctioning crankcase ventilation system can be increased engine oil consumption. Refer to SI B11 03 08 for measuring specifications and procedures.
Turbocharged Engines
Engines that are fitted with a turbocharger(s) will consume more engine oil than naturally aspirated engines (non-turbocharged engines). In this case, a turbocharged engine could require topping of engine oil more frequently. For vehicles with N63 and N63T engines, refer to SI B11 01 13 for additional details.
2013 F10 Alpine White
2013 LS460L
2011 Audi Q7
      06-07-2013, 01:14 PM   #15
thebishman
Drives: F82 M4
If my M5 ever starts using 2.5 liters every 1,000 miles its gone! lol
Luckily I'm burning about a litre every 1,500 miles so far at 9K miles.
      06-07-2013, 01:36 PM   #16
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
Drives: 16 M5, 18 ZL1 1LE
I'm on my second quart at 9000 miles.
