      02-21-2014, 02:55 PM   #1
DrKevM5
DrKevM5's Avatar
Drives: F85 X5M, F87 M2
'13 NV Grille upgrade to LCI
Maybe I'm late on this one, but i just found out that the NV housing and module are different on the '14s so I couldn't swap out for the new grille. Spoke to IND this morning and they stated that they may be able to make a custom modification on their grill to fit the '13s. Love that company...hope they follow through. BTW, I also found out that the RPI scoops will not fit behind the NV module so I'll be posting mine up for sale. I was one of the first to get them and they neglected to note that it wouldn't fit.
'16 X4 M40i Dark Graphite/Saddle Brown
'16 M2 Long Beach Blue/Black, 6MT
'16 X5M Black Sapphire/Black Merino
      02-21-2014, 03:46 PM   #2
avlnch
Drives: 2013 Individual M5
Are the BMW LCI N/V Performance front grilles out yet?
I am hoping to retrofit one onto my car as well.
      02-21-2014, 04:27 PM   #3
DrKevM5
DrKevM5's Avatar
I don't think so. But don't you have a '13?
      02-21-2014, 05:05 PM   #4
boots
Curve Thrasher
boots's Avatar
271
ah maaan
Country run
      02-21-2014, 05:11 PM   #5
avlnch
Yeah I want to replace my 2013 M5's pre-LCI performance n/v front grilles with LCI performance n/v front grilles (black chrome).
Even considering removing the NV (if it's simple to do which I assume it is) to use the grilles. Until a permanent N/V solution comes along.
      02-21-2014, 05:34 PM   #6
DrKevM5
DrKevM5's Avatar
Actually, that's not a crazy idea. I never use my night vision. I wonder if that would throw off other systems. I blew a fuse trying to replace my interior bulbs with LED and 3 systems went to hell.
      02-21-2014, 06:20 PM   #7
avlnch
Not sure if unplugging the NV would throw an error code on the iDrive.
If it does, then I would need to change a code or code out NV by changing the VO - that way the car would think it doesn't have the NV option.
      02-21-2014, 06:47 PM   #8
DrKevM5
DrKevM5's Avatar
Spoke to my tech, he said that would throw a bunch of codes. Have faith that IND can take care of us. We're counting on you Nate!!!
      02-21-2014, 07:01 PM   #9
avlnch
I have the LCI MP grilles coming in the mail. Should have them on Monday or Tuesday.
I am going to remove night vision from my vehicle order (VO) by coding it out. Then install the front grilles and it shouldn't throw any codes.
Leaving it unplugged I would think would throw a code. But if the car believes it doesn't have N/V option, then it shouldn't throw any codes as a result of the unplugged cable.
      02-21-2014, 09:01 PM   #10
DrKevM5
DrKevM5's Avatar
You're a brave man. Keep me posted.
      03-05-2014, 08:58 PM   #11
avlnch
@DrKevM5
Just got around to doing my install.
It was not easy, and did not go as planned. You can see I didn't install my left grille laser jammer. The stuff behind the grille is my jammer and NV cables I zip tied off until I find part number for a part I am missing.
I have a lot of info on this.. will post more info soon.
      03-05-2014, 08:59 PM   #12
znammzM6
Drives: 2014 SG M6
I'm in the same boat....=/ want the new LCI grill but cant get it due to NV, hope IND will come through with it just like u.
      03-05-2014, 09:10 PM   #13
avlnch
You can have IND order the LCI NV front grille in chrome and when it's arrives they can paint it for you.
That is what I did, however I ran into an issue and temporarily installed the non nv until I find the parts I need to secure my N/V camera into the LCI grille.
      03-05-2014, 09:19 PM   #14
avlnch
Notes on install:
1. BMW changed suppliers for black chrome parts. It does not match the old supplier black chrome. Most interesting, the black chrome looks identical to 668 black paint.
In the photo I posted earlier: the right front grille is black paint, the left front grille (NV side) is black chrome. You cannot tell a difference between the two.
2. After I transferred my NV camera into the new LCI housing, the back plate that secures the camera did not fit. I need a new "LCI part" (that being the back plate). Working on finding the part #.
Temporarily, I installed the non-nv left front grille. I zip tied my LI jammer and the NV plug together and to the radiator bracket. I taped over the plug with electrical tape to prevent water from getting into the connector. I tucked the NV lens washer fluid tube away.
3. I started the car up with the NV unplugged and no error appeared. I turned the lights on and off, and I press the NV button to enable it, however pressing the button did nothing. So currently I can say that the car is error free with NV unplugged. I haven't driven the car yet after I unplugged it. I don't think that would matter though.
      03-05-2014, 10:36 PM   #15
leatonniu
Drives: bmw
      03-05-2014, 10:48 PM   #16
avlnch
Unplugging NV? Nope, don't think it would affect anything.
I was planning on coding NV out by removing it from the VO. But then after seeing that unplugging it causes no error, there was no need to code it out.
But again this is temporary until I get the part I need (cover to secure NV camera). Then I am going to install the NV grille.
      03-06-2014, 01:48 PM   #17
DrKevM5
DrKevM5's Avatar
Ok, so it's just the camera housing that's changed, not the camera unit itself. Wow, if you can source the housing back, we're golden. You, Sir, are the MAN!!!
      03-06-2014, 02:00 PM   #18
mwlmd
mwlmd's Avatar
Are the non-NV LCI M performance kidney grills available to order? If so where is the best place to order them (for USA customers)?
Thanks,
matt
F10 M5
Alpine/Sakhir/Anthracite/DCT
HRE P101. Akrapovič evolution. H&R. Bell StiR+ Laser Interceptor quad. IND cosmetics. 3M CR50.
      03-06-2014, 02:07 PM   #19
patb23
patb23's Avatar
Drives: '14 M5 CP & '62 corvette
2014 BMW M5  [5.00]
1962 Corvette  [5.00]
Thanks,
matt
IND Sells them
http://ind-distribution.com/ind/cate...ront-grill-set
2014 ///M5 Singapore Grey Metallic, Black Extended Merino, Anthracite Wood Trim, Comp Pkg, Driver Assistance Plus, Exec Pkg, Lighting Pkg, B&O, 343M Wheels (11.597 @ 122.44MPH)
Mods: Gloss Black Wheels, 35% 3M Tint, IND Gloss Black (LCI Grilles, Side Markers, Rear Emblem) IND M5 Floor Mats, RKP (McRae Splitters & Rear Diffuser), Passport 9500ci, Suntek PPF-C, M Door Projectors
1962 Corvette Convertible Red/Black (Gone:'11 750Li, '09 Z06, '08 550i)
      03-06-2014, 03:52 PM   #20
mwlmd
mwlmd's Avatar
Originally Posted by patb23 View Post
I believe the IND ones are painted chrome. I was wondering if BMW has released their OEM gloss black M perf LCI kidneys.
F10 M5
      03-06-2014, 04:59 PM   #21
avlnch
No, but there is the Night Hawk front grille which is black chrome.. In reality it matches black paint 668. See my post above and photo of the two front grilles.
Do you need NV or non-NV?
      03-06-2014, 06:23 PM   #22
mwlmd
mwlmd's Avatar
I need non-NV version. The black chrome looks nice but the rest of my trim is gloss black so I would like gloss black (same as my current non-LCI M perf kidneys).
I also have Laser Interceptors that I would have to re-mount.... PITA.
F10 M5
