02-21-2024, 10:29 AM | #23 | |
Rep 24,943
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
02-21-2024, 10:35 AM | #24 |
Rep 24,943
Pic from today at Bahrain
02-21-2024, 11:02 AM | #25 |
#buildnotbought
11109
Rep 4,930
Wow that RB20 looks totally different from the competition regarding the sidepods/air inlets. (all the other cars are mainly RB19 copies)
There are now basically 3 inlets: the vertical slotted ones (also seen at the reveal), theres a horizontal inlet slot at the front under the sidepod (difficult to see, but they're there), and there are inlets on the front/inside of those bazooka ducts. Anyone knows which ones lead to cooling radiators? Normally thats the front inlet on the sidepod (because that's usually the only inlet of real size), but with this car...I have no idea. If it's the vertical ones, it might just be that the sidepods are pretty much empty and that the shape of the sidepod and the airflow inside mainly have an aerodynamic function, and a zeropod design can be really easily made (so the packeaging of the engine/gearbox/cooling is already fit for that. Of course if the cooling is more to the center of the car instead of inside the sidepods, that increases agility as less mass is off axis. This is going to be an interesting year regarding car development at RB I think. It would be very interesting to see if they would come with a zeropod update and make it work.... Even with having lost quite a few top engineers to the competition it looks like RB is aerodynamically still leaps ahead on the competition. Last year in monaco we saw the underside of the RB and the Williams, and the aerodynamic difference that came to mind with me was: And I'm getting that vibe again regarding the sidepod/air intakes with most of the field
02-21-2024, 11:18 AM | #26 |
Rep 4,242
So the zero sidepods work eh
Blindside_1376755.00 |
02-21-2024, 11:21 AM | #27 |
Rep 580
Killed by Death13155.00 |
02-21-2024, 11:26 AM | #28 |
Rep 24,943
The RB20 zero sidepod (upgrade) design is for April 5-7 at Japan (Suzuka)
As you can see !
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 02-21-2024 at 11:36 AM.. |
02-21-2024, 11:31 AM | #29 |
Rep 4,672
Right now day 1, there’s not much to take away other than what the actual race spec cars will look like, at least for Bahrain. Will likely have a better idea come Friday when both drivers would have been behind the wheel and there’s much more “data” to “analyze” over.
///M Power-Belgium64686.00 M5Rick61783.00 |
02-21-2024, 01:02 PM | #31 |
Rep 19,954
Here's TacticalRab on today
Look at Wolff @ 6:20 ..and GP @ 11:36 Last edited by M5Rick; 02-21-2024 at 01:27 PM.. |
///M Power-Belgium64686.00 |
02-21-2024, 01:39 PM | #32 | |
Rep 24,943
As I said in 2020/2021 : This is just the beginning ... MKSixer : It's impossible to beat Mercedes and Lewis with a energy drink maker ! MAX : I'll speak at the track !
02-21-2024, 01:48 PM | #33 |
Rep 24,943
Yeah .That's the part of Wolff that I really like to see. LMFAO !
02-21-2024, 02:04 PM | #34 |
Rep 19,954
02-21-2024, 02:13 PM | #35 |
Rep 24,943
And this ...
This pic has been nominated as snapshot of the day ... Wolff wants to buy information !
02-21-2024, 02:22 PM | #36 |
Rep 24,943
02-21-2024, 02:27 PM | #37 |
Rep 19,954
02-21-2024, 03:52 PM | #38 |
Rep 24,943
02-21-2024, 03:57 PM | #39 |
Rep 19,954
///M Power-Belgium64686.00 Killed by Death13155.00 |
02-21-2024, 05:32 PM | #40 | |
Rep 19,954
https://racingnews365.com/the-trick-...ds-were-hiding |
02-21-2024, 05:34 PM | #41 |
OHIO STATE
742
Rep 725
Drives: 2021 BMW M340i
Can't wait for the season to start and Red Bull to dominate again...or shall I say...Max Verstappen to dominate again!
Present: 2021 BMW M340i Mineral White
Past: 2018 BMW X5 Mineral White, 2018 BMW 340i Alpine White, 2016 BMW F15 X5 xDrive / Glacier Silver, 2011 BMW 335xi / Alpine White, 2008 BMW 135i Sedona Red |
02-21-2024, 05:43 PM | #42 |
Rep 3,659
02-21-2024, 08:52 PM | #43 |
Rep 41
[QUOTE=GuidoK;30922410]If it's the vertical ones, it might just be that the sidepods are pretty much empty and that the shape of the sidepod and the airflow inside mainly have an aerodynamic function, and a zeropod design can be really easily made (so the packeaging of the engine/gearbox/cooling is already fit for that.
Of course if the cooling is more to the center of the car instead of inside the sidepods, that increases agility as less mass is off axis. /QUOTE] When I first saw the images of the car the vertical slots remind me of a boundary layer splitter plate seen on supersonic jet fighters like the F-4 Phantom II, F-14 Tomcat and F-15 Eagle. Obviously the car is not intended to drive at supersonic speeds but the aerodynamic problems may well be similar - slow, turbulent air close to the body causing vortexes in faster moving air and consequentially, increased unwanted drag. My guess coming from an aviation context is that that slot vents the air underneath the car in a low pressure area to help smooth the airflow over the sides of the chassis or alternatively they could pass the air over the radiators to create a net thrust via the Meredith Effect to accelerate the airflow further back. |
02-21-2024, 10:41 PM | #44 |
Rep 10,736
Looks like another horribly boring year on tap. Early of course, but over a second gap is awful for good racing. Oh well.
