View Poll Results: How do you listen to Mp3 in your M5? | |||
USB cable my iphone, so I can also charge it. | 18 | 66.67% | |
Blutooth, I get music and phone calls. | 7 | 25.93% | |
CD is the only way to best quality | 1 | 3.70% | |
Copy Mp3 onto M5's HDD | 1 | 3.70% | |
Voters: 27. You may not vote on this poll |
05-29-2014, 12:41 PM | #23 |
Rep 430
Orich in this forum mentioned that he is able to play FLAC files. Has somebody else in this forum been successful playing them?
Reason is that even the 2014 NBT Navigation,Entertainment,Communications Owners manual only lists the following formats as playable on the M5 (2014) system: DVD: DVD-ROM, DVD-R, DVD+R, DVD-RW, DVD+RW, DVDR-R DL, DVD+R DL, DVD video, CD-ROM, CD-R. CD-RW, CD-DA,VCD, SVCD Compressed audio Files: MP3, WMA, AAC There is no mention of any lossless format. My take is that the M5 system only looks at the extention of the file and tries to play only those files, which is the reason why I chose the lossless windows media wmv music file version which has an extension of .wma and since my files were transcoded in windows media using the lossless format, not the compressed version, all aspects of the original source are present.
05-29-2014, 09:22 PM | #24 | |
Rep 228
I have software version MN-002.017.007, and it plays .flac files.
What's the latest software version? How do I get an update? I have not tried ALAC or WMV, but I tested a few more flac files, but not all of them are detected although they are all .flac file extension. I have not figured out why some flac plays but others could not be detected. Perhaps it has to do with compression level of the file? I checked all my files using Winamp and they all seems to be Sample rate = 44100hz, Bit per sample = 16, but I guess they are not all the same. Quote:
"Speeding is like farting - you have to know when it’s inappropriate." - James May
05-30-2014, 06:58 AM | #25 |
Rep 430
You may already have the latest media software, but anyway you can download software updates from the bmw site http://www.bmw.com/com/en/owners/nav...gion=&country=
You have to enter the last 7 characters of your car's VIN to get the correct one. The file downloaded will have a .bin extension which you put in the root of a thumb drive (FAT/FAT32 formatted) and insert in the car's USB connection at the central console. In the idrive menu under settings you should see something like software update. Myself, I tried to do an update but keep getting the message that I already have the latest. Anyway, from what I can gather, .flac files may be supported (by NBT but not CIC) in some car models. What I think is happening is that BMW is still testing with lossless formats (beginning with .flac) so even in their documentation, they have not mentioned anything about those formats. Also, maybe somebody in this forum could tell us the possibility of coding lossless formats because if I remember correctly, there is somewhere to specify "ogg-vis" as a valid codec. So in the meantime, I will stick with .wma lossless files (24bit 44Khz) as that seem to be fine.
05-30-2014, 05:42 PM | #26 | |
Rep 28
05-30-2014, 05:46 PM | #27 |
Rep 28
Hey you guys are my best friends now as trance/trap/dance/techno music is what i live for Glad to know that B&O is able to handle it well...!!
05-30-2014, 07:41 PM | #28 |
Rep 430
In general lossy compressed audio is more than adequate especially if listening to modern and pop music as the frequencies produced are between 80Hz to 16Khz. Most people cannot hear anything lower than 50Hz unless one is an elephant (but one can feel the vibration), or greater than 15Khz. Not to disparage those who listen to non-classical music but streaming via bluetooth (audio has been compressed and will hardly exceed the 15Khz range) will be very much acceptable/enjoyable. However, to the few, like me, who in addition to pop/modern music, enjoys the classics performed by an orchestra ensemble where the frequency range can be 80Hz or less and above 24Khz, the absence of the high frequencies can be unnerving. These frequencies may be beyond the hearing range of the majority, however, in my case and age (validated in my last medical hearing test, 4 months ago) I can still hear sound frequencies up to 22Khz. Listening, even while driving to some of Dmitri Shostakovitch's Symphonies (whose string section produce sounds that can reach 18Khz and above) in a lossy format such as MP3, results in complete dead silence which only a lossless encoded format can fix. BTW, even modern/pop music encoded in a lossless format do produce much richer sounds than one that is encoded in a lossy format such as MP3 (but of course, one must have the capable "ears").
