06-30-2014, 09:11 AM | #89 |
Rep 792
What's your email ill send it to you but check with terry when you get it and make sure it's the right firmware.
I have two on my desktop but i think the other one is the stage 2 firmware for meth set up. I believe I'm sending you the right one |
07-02-2014, 11:21 AM | #90 |
Rep 292
Looking for the new firmware as well can't find it on his site. does anyone have a link?
07-02-2014, 01:20 PM | #91 |
Rep 664
07-05-2014, 03:26 AM | #92 |
Rep 611
Last night, I tried out 7.5psi with VP 109 race gas n meth.
The result was I strongly believe our engine can do much more than that, will keep pushing it to the limit. For those running 3 or below, don't waste your time. The secret is to do a proper adaption of the engine n after which u can do probably anything u want! Good luck! Last edited by Andym3100k; 07-05-2014 at 08:40 AM.. |
07-05-2014, 10:10 AM | #93 | |
Rep 2,203
07-05-2014, 02:08 PM | #94 | |
Joint Chiefs of Staff
4980
Rep 116,110
Mike |
07-05-2014, 02:20 PM | #95 | |
Rep 961
07-05-2014, 05:18 PM | #96 | |
Rep 611
Will do a dyno soon to see what is the result, hopefully next Thursday if they r available. Thks Last edited by Andym3100k; 07-05-2014 at 05:46 PM.. |
07-05-2014, 09:43 PM | #98 | |
Rep 2,176
07-05-2014, 10:51 PM | #99 |
Rep 611
U mean they have set it at max 6psi? So even when I up boost to 7.5psi it will still stay at 6? Can't be cos the log that I got was much higher than it was on 6psi.
07-05-2014, 11:11 PM | #100 | |
Rep 611
07-06-2014, 07:27 AM | #101 | |
Rep 792
Good luck man |
07-06-2014, 07:56 AM | #102 | |
Rep 611
I'm using the JB4 mobile apps from my old N55 car using a Samsung note 3 to log, it comes with a graph too. Will only show target boost, actual boost & a very odd RPM number. So I'm basically just looking at the target n actual boost. |
07-06-2014, 08:46 AM | #103 | ||
Rep 2,176
07-06-2014, 10:07 AM | #104 |
Rep 611
Good idea, will hook up one asap.
2014 M6 GRAN COUPE FULL HAMANN WIDEBODY.
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19 |
07-06-2014, 10:19 AM | #105 | |
Rep 611
it said upload errors, invalid file csv, can i email to u?
07-07-2014, 06:47 AM | #106 | |
Rep 961
07-07-2014, 06:50 AM | #107 |
Rep 961
Also, I find its easier to tell if it has adapted when it feels strong on the low end with minimal gas. If it feels sluggish and weak, more then likely it's still adapting.
07-07-2014, 08:16 PM | #108 |
Rep 611
I just cut & paste the log, as i said it has a funny rpm number which i got it from my jb4 mobile apps thru my samsung note 3 phone. These are in 3rd gear pull onwards to 5th, if im not wrong highest boost level should be around 23.6psi. i dont know whether is it right or?
RPM ECU TAR BOOST 483 7.8 10.8 12.4 471 8 11 12.5 479 8.4 11.2 12.8 473 8 11.1 13.1 488 7.5 11.1 13 523 8.2 11.5 13.1 539 8.3 11.9 13.8 545 8.4 13.4 14.5 543 9.4 14.5 16.1 586 9.9 14.5 16.1 544 10.8 15.3 17.3 553 10 15.3 17.3 589 10 15.4 17 601 10.6 15.4 17.1 546 10.1 15.1 17.2 547 9.8 15.5 17.1 586 9.6 15.9 16.8 580 9.6 16.4 17.4 537 11.6 16.2 17.6 575 11.6 16.3 17.5 552 11.5 16.6 18.2 567 11.1 17.1 18.2 620 11.1 17.6 18.7 624 10.8 17.9 19.1 634 11.5 18.4 19.5 627 11.5 18.3 20 661 11.7 19.1 20 687 11.7 19.3 20.5 688 11.7 19.6 21 663 12.4 19.8 21.1 671 12 20.1 21.5 669 14.4 20.1 22 728 13 20.6 22.7 681 14.7 21 23.2 684 15.7 21.5 23.6 694 13.4 21.6 23.5 692 12.9 21.6 23.5 695 12.8 21.7 23.4 681 13 21.5 23.1 718 12.7 21.2 22.9 660 14.5 20.7 22.8 671 12.8 20.8 22.8 691 12.5 20.8 22.8 667 12.4 20.7 22.6 669 14.3 20.7 22.5 694 14.3 20.7 22.9 702 15 22.9 25.1 699 12.5 21.5 24.4 686 12.8 21.5 23.3 664 12.6 20.4 22.4 670 14.8 20 22.3 669 12.7 20.8 22.5 684 11.8 20.8 22.5 662 14.7 20.4 22.2 672 12.7 20.4 22.5 683 12.6 20.3 22.3 632 13.3 20.3 22.2 670 12.2 20.6 22.5 731 12.7 21.5 24.3 720 14.4 21.5 23.8 660 14.4 21.5 23.8 587 9.9 16.4 18.7 573 9.6 15.2 17.4 534 9.7 14.2 15.6 513 9.6 14 15.6 564 9.2 14.1 15.5 580 10.6 15.4 17.3 615 10.6 16.1 18.2 610 12.7 18.7 20.1 650 12.2 18.7 21.4 653 12.5 20.4 22.7 702 12.5 21 23.4 689 13.3 21 23.7 685 12.9 21.2 23.6 672 14.8 21 23.6 690 13.5 20.6 23.4 681 13 21.2 23.4 689 15.1 20.7 22.8 658 14.2 20.7 22.4 680 12.6 20.4 22.6 682 12.9 21.2 22.8 696 12.7 21 23 670 12.8 20.7 22.8 695 12.7 20.8 23 669 13 20.7 22.8 677 15.4 20.7 23 673 12.5 20.8 22.8 660 13.2 21 22.8 729 12.8 20.8 23 665 12.4 20.8 23 672 12.9 21.2 22.8 679 14.4 21.3 23 676 12.4 21.2 23.1 673 12.4 21.3 22.7 684 13.5 21.1 22.9 703 13.6 22.1 24.4 681 14.7 22 24 664 15.2 21.9 24.2 688 14.1 21.9 24.2 718 15.3 22 24.1 779 14.1 22.2 25 714 17.2 24.2 27 620 11 21.1 22.9 419 6.8 11.2 12.1 380 6.1 9.5 10.3 362 5.1 7.3 8 368 4.8 5.8 6.9 333 3.7 4.9 5.5 319 4.1 4.5 5.1 318 3.7 4 4.7 313 3.7 3.7 4.3 300 3.4 3.2 3.8 298 3.4 3 3.7 296 3.3 3 3.5 293 3.3 2.9 3.4 291 3.2 2.8 3.3 290 3.2 2.8 3.3 289 3.1 3 3.2 288 3.1 2.7 3.2 287 3.1 2.6 3.1 286 3.1 2.6 3.1
07-07-2014, 09:40 PM | #109 | |
Rep 792
No worries though, if you can that will be great G |
07-08-2014, 12:28 AM | #110 |
Rep 611
Will do it once I got back home tonight, my Samsung can't attached anything to the forum page.
