04-17-2015, 08:21 AM | #1 |
Rep 611
BR tune stack with bms plus SSP 900+ ft/lbs.Torque Clutch.
Just managed to replace the stock clutch to SSP BMW 900+ ft/lbs.Torque Clutch kit, the drive is very smooth. No jerking or knocking while changing gear & is a straight replacement very easy fix.
Going to run in the clutch for a while then let the beast out of it, can't wait to test it with my 100hp nos wet shot! Previously running bms map 3 with all the same mod as stated best 100-200 was 7.3sec, now after stacking both together I got best run for 100-200 at 6.65sec a gain of 0.6sec & a distance of 30m gain too (a good 6 car length) Best was 6.2sec with 30% of E85 & 100shot. 2014 S63TU M6 GRAN COUPE FULL HAMANN WIDEBODY BR tune stack on Bms meth kit to BMS S2 ZEX 100hp Wet shot Custom K&N Direct Open Port cold air Intake SS DP n FULL ARKA EXHAUST SYSTEM 20" R888 Front 285/30/20 Rear 315/30/20 SATIN WRAP
2014 M6 GRAN COUPE FULL HAMANN WIDEBODY.
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19 Last edited by Andym3100k; 05-29-2015 at 06:34 AM.. |
04-17-2015, 01:54 PM | #5 |
Rep 1,349
Drives: BMW F80 M3
Hi Andy,
My best 100-200 with N55 pure stage2 is 6.64 with stock flash jb4 fbo and meth That m6 is just too heavy! But it looks nice Greetz, Peter |
04-17-2015, 03:30 PM | #6 |
Rep 611
Hi Peter, my friend"s (Joseph) which is also a member in N54 forum having his F30 N55 pure stage 2 with the same set up like u did 9.7sec for 100-200. I just don't understand why the oversea friends can always get a better timing than us in Singapore is always the case to all our cars here.
04-17-2015, 03:33 PM | #7 |
Rep 611
Our stock m5 run 9.1sec for 100-200.
Plug in a G-power PIGGYBACK with everything stock did 8.6sec for 100-200. Last edited by Andym3100k; 04-17-2015 at 05:07 PM.. |
04-17-2015, 04:34 PM | #9 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Your car looks the business!
04-17-2015, 04:53 PM | #10 |
Rep 611
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19 Last edited by Andym3100k; 04-20-2015 at 08:06 AM.. |
04-17-2015, 06:32 PM | #11 |
Rep 611
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19 |
04-17-2015, 06:49 PM | #12 |
Rep 1,805
I never imagined I would see such a highly modified M6 GC! I hope you have a road / track to do it justice!
04-17-2015, 11:07 PM | #13 | |
Rep 1,349
Drives: BMW F80 M3
04-18-2015, 04:16 AM | #14 |
Rep 611
04-18-2015, 09:13 AM | #15 |
Rep 1,805
Tell me about these cold air intakes you have please.
04-18-2015, 09:18 AM | #16 |
Rep 611
04-19-2015, 03:44 AM | #17 | |
Rep 643
Drives: BMW M5 F10
Garage List 2013 BMW M5 [0.00]
2011 Alpina B3S Bit ... [9.50] 2010 Alpina B3 Biturbo [10.00] 2009 Alpina B5S [10.00] |
Should be 7.8 100-200 stock. |
04-19-2015, 07:28 AM | #18 | |
Rep 611
We are a team of friends that drag at least 4 times a week, we know better than anyone else in Singapore. |
04-19-2015, 10:20 AM | #20 |
Rep 611
Yup hope so after I run in the clutch, still have my upgrade turbo sitting in the store lol....... Btw next week will be doing my nos spray on the water to air cooler hope to bring down the intake Tem further.....
04-19-2015, 10:35 AM | #21 | |
Rep 1,805
With all your modifications do you have an idea on what hp you are at now?
04-19-2015, 06:20 PM | #22 | |
Rep 611
Last did stock without Cat was 534ps With bms 3psi was 583ps And bms 4psi with meth was 598ps All with stock exhaust but decat & drop in K&N filter. I wouldnt be hitting the dyno soon, still need to do too much things (fine tune it with the larger turbo when I hv the software if possible. I'm using Qstarz to check on timing cos I don't trust my butt dyno. Last edited by Andym3100k; 04-19-2015 at 08:02 PM.. |
