02-14-2018, 07:09 PM | #1 |
Rep 3,163
Quampa | KW V3 Coilover for BMW M5 F10 - Lowest prices
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression Dampening allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound Dampening adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
General Features: Dampening technology with individually adjustable rebound- and compression technology inox-line* stainless steel technology Individually height adjustable Adjustment parameters approved by the German Technical Control Board (TÜV) High-quality components for long durability Infinitely variable rebound Dampening adjustment 14-way adjustable compression Dampening Unique, individually working Dampening force adjustment Comprehensive documentation for easy use Specific Features: with adjustable compression and rebound Dampening TÜV approved Front lowering adjustment ranges (min.-max.): 15-45 mm (0.6-1.8 inches) Rear lowering adjustment ranges (min-max): 10-40 mm (0.4-1.6 inches) Front Spring Rate: Progressive Rear Spring Rate: Progressive Fitment: BMW M5 F10 (5L) Sedan (bundle including EDC delete unit) 12-16 Notes: Height adjustable on the front and rear axles (threaded strut housings) Valving is adjusted by adjustment knobs, rebound is only adjustable if the top of the piston rod is accessible. This will depend on the design of the vehicle. Electronic Dampening control has to be deactivated. Deactivation kit is included in the delivery. Part number with EDC: #35220098 Part number without EDC: #35220097 Contact us for best pricing. |
Tags |
coilovers, kw suspension, quampa |
