03-23-2018, 09:07 PM | #1 |
Rep 3,163
QUAMPA | Dinan Exhaust & Intake Combo Package - Best prices
The F10 M5 is one of the most powerful M-cars ever to leave Munich and we have the high performance exhaust solution to give this super-sedan an even more aggressive tone.
Exhaust Product Description SKU# D660-0044 (chrome/polished tips) SKU#D660-0044-BLK (black tips) Dinan’s Free Flow exhaust system features 100% stainless steel construction measured to exact specifications to ensure proper fit via factory hangers and mounting points. Dyno tuned for maximum exhaust flow with minimum backpressure, this system is designed to provide a more aggressive sound under acceleration, while reducing drone inside the vehicle, thanks to Dinan’s exclusive Helmholtz Chamber and Butterfly Valve technologies. The exhaust gasses exit through larger laser engraved ultra durable satin black ceramic coated quad tips. Benefits of the Free Flow Exhaust + Improve performance by 8 horsepower + Throaty, deeper sound + 100% 304 Stainless Steel Construction + Helmholtz chamber to remove drone + Incorporated Butterfly Valve technology + Simple installation using high quality BMW clamps and hangers + Quad 3.5" laser engraved black ceramic coated exhaust tips with Dinan logo + "Straight through" canister design Tip options: Black or Chrome/Polished Intake Product Description SKU#D760-0035 The F10 M5 Dinan high flow carbon fiber cold air intake, like most Dinan products, has a sleek and functional appearance that embodies high performance. The F10 M5 cold air intake allows cool outside air to be pushed into the engine via a pair of supplemental carbon fiber intake ducts located at the front of the engine bay. The M5 cold air intake system was carefully designed within tight packaging constraints and in consideration of ideal aerodynamic diffusing angles to optimize the efficiency and performance of this induction system. Each duct leads combustion air through a custom designed intake assembly that has a larger than stock metered air flow housing, as well as a Dinan conical air filter with a 77% larger capacity. Dinan engineers have painstakingly developed custom tooling to ensure the entire Dinan cold air intake system is sealed like a factory replacement, thereby preventing hot air from the engine compartment to compromise its effectiveness. The stock air inlets are left intact and fully functional to provide a new total of four air intakes into the engine for maximum airflow. Improved induction airflow offered by Dinan cold air intake systems increase engine performance, even more so if used in combination with other performance enhancing Dinan products. Benefits of Dinans Cold Air Intake: + Maximum peak power of 693 HP and 651 lb-ft of Torque utilizing Dinan Stage 2 components (DINANTRONICS Performance Tuner, intake and exhaust). A difference of 13 HP and 7 lb-ft of torque from Dinan Stage 1 (D-TRONICS Performance Tuner Only). + Dinan proprietary Injection molded Dinan MAF housings are larger than stock + Stock air filters are replaced with 77% larger Dinan conical air filters. + Entire Dinan Intake system is sealed like a factory replacement to ensure only cold outside air and not hot air from the engine compartment is being utilized. + Stock System Stays Completely Functional + Carbon fiber air box lids and intake ducts + Raised Dinan logos are laminated into the carbon fiber intake + Rubber hoses, mounting brackets, & hardware included. CONTACT US FOR BEST PRICING ON A PACKAGE DEAL!!! |
Tags |
bmw m5 f10, dinan exhaust, dinan intake |
