11-17-2018, 07:49 AM | #1 |
Rep 594
Need new mechatronic
Need new mechatronic for m5 f10
Can any one help for price please ? Availability? Offer ?
Mohamed kamal elkasaby
11-17-2018, 05:30 PM | #4 |
Rep 965
The electric portion that assembles to the valvebody.
To the OP - Be careful if you choose a used mechatronic, I attempted to install one used and I could not re-code it. Tried every option thru ISTA and it stated not able to re-code. No communication to transmission. I had to remove the transmission and re-install the original unit from the car |
11-17-2018, 10:36 PM | #5 | |
Rep 435
11-18-2018, 05:40 PM | #7 | |
Rep 594
But faulty in ecu not mechatronic Ecu send wrong values to mechatronic (body valve ) I need to replace new ecu
11-18-2018, 05:42 PM | #8 | ||
Rep 594
But cant switch p to n Ews protection Cant remove it like all bmw cars Dont know why They said not support yet
11-21-2018, 02:53 PM | #9 |
Rep 965
11-21-2018, 05:26 PM | #10 | |
Rep 594
But i think you used mechatronic for m3 e series Thats sure bro
11-21-2018, 06:22 PM | #11 | |
Rep 965
This is the message from ISTA : The measures plan execution is not possible, since the maximum number of possible programming procedures has been reached on the following control units : EGS These control units can no longer be programed and must be replaced |
11-21-2018, 06:27 PM | #12 | ||
Rep 594
if you use tools like autohex,explorer You can program it separate , and it will take vin number easy Engine start too But cant move cause isn ews protection cant reset it
11-21-2018, 07:01 PM | #13 | |
Rep 965
The used part was supposed to be able to be programmed with my tool, otherwise I would not of purchased it. My ISTA is registered with BMW and I receive current updates. When I talk to trusted tuners that use aftermarket tools like you are describing, they state the unit is non-programmable just like my ISTA is telling me. We also tried ESYS which is the development software for BMW engineer. No luck with that either. The unit I received is no good. Maybe you had better luck but not with my scenario Last edited by schnell1982; 11-21-2018 at 07:54 PM.. |
11-22-2018, 04:49 AM | #14 | ||
Rep 594
If you are used donor ecu Before programing or recode You find note compatible or not An i found compatible aNd programmed too Taked vin number For isn i can reset it by autohex too For all bmw cars Except dct 🤷🏼*♂️
11-22-2018, 12:30 PM | #15 |
Rep 269
The mechatronics unit on my first M5 was replaced by my local BMW dealer. It was part #28-60-7-846-717 and 28-60-7-842-861. Shockingly expensive; was covered under warranty. The line item on the RO says "Replacing mechatronics (after vehicle diagnosis) (without programming encoding, see 61 00 ...)"
So, not sure how they were able to get around that part. Maybe because the replacement had never been coded before?
2021 Brands Hatch Grey M5 Competition
11-23-2018, 05:34 PM | #16 | |
Rep 594
If you used full part mechatronic and ecu It must be programmed or they send it programing I included by vin If you used your mechatronic only with out ecu You no need to programing it
11-26-2018, 07:47 AM | #17 |
Rep 269
Well for sure they shipped in the mechatronics unit form Germany (took a week), and they didn't replace the ECU. The service tech and I stayed in close contact as he was a personal friend. Either way, the job was a shit show and added 13 DAVIS days to my car which ws later bought back by BMW NA
11-26-2018, 02:30 PM | #18 | |
Rep 965
11-26-2018, 06:26 PM | #19 | |
Rep 594
10-09-2022, 08:59 AM | #21 |
Rep 5
I have an M3 F80 which has the same issue and needs DCT replacement. If I get a DCT replacement, connect the original mechatronic & ECU there is no issue in getting it running?
