02-14-2019, 04:39 PM | #1 |
Rep 102
FS: OEM CCB Carbon Ceramic Rotors Front & Rear (20K Miles) F10 F06 F12 F13
Up for sale is a complete set of Carbon Ceramic Rotors for the BMW M5/M6. I purchased these as a backup set a while back but dont think I will need them as I dont drive much anymore. I will post rear weight measurements in a couple days. Front Rotor 1 Weight: 7946 g (minimum weight: 7830 g) Front Rotor 2 Weight: 7922 g (minimum weight: 7810 g) They came off an F10 M5 with 20k miles. I would prefer local pickup in SO CAL. Last edited by Jim93001; 04-05-2019 at 06:46 PM.. |
02-14-2019, 07:56 PM | #2 |
Rep 145
To quote the BMW CCB Technical Bulletin :
“To operate Ceramic Brakes properly Bmw states that a complete Brake Kit is required not just the disc’s and calipers (you must install the specific Bmw Brake Booster as well).” “Also Ceramic Brake disc’s if not handled properly and/or are subject to stone/physical damage can render them structurally unsound and subject to catastrophic failure.” |
02-14-2019, 08:03 PM | #3 | |
Rep 102
02-14-2019, 08:17 PM | #4 |
Rep 145
Bmw M CCB Service Bulletins
02-14-2019, 08:23 PM | #5 |
Rep 145
CCB Wear
“Over in the M2 forum we've been having a debate on the pro's and con's of CCB's. I mentioned that besides the visible CCB wear indicators you also must disassemble and weigh the ceramic rotors - for wear. Its not necessary to do that now - although there is a min ccb weight loss of 100 gram per rotor. Here are some interesting pdf's on checking for wear on CCB brakes. “
02-15-2019, 08:33 AM | #7 |
Rep 102
03-03-2019, 10:29 AM | #14 |
Rep 102
03-04-2019, 10:49 PM | #15 |
Rep 193
03-04-2019, 10:52 PM | #16 |
Rep 102
Tags |
carbon, carbon ceramic brake, carbon ceramics, ccb, ceramic brakes, mccb, rotors |
