07-16-2019, 03:01 PM | #1 |
Rep 227
295 vs 305 on 21's again.
Hi all,
Got a set of BBS RX2 in 21 front et23, 9j rear et28, 10.5j At the same time as sorting out the wheels, I will install KW HAS, so I am trying to avoid any issues before spending money on mps4s. I know there is millions of threads around tyre/wheel combo but I don't seem to be able to find a definitive answer for me. I am thinking of going 265 30 front and 305 25 at the back but I can see straight away that front will have to get around 7-10mm spacer because of the brake caliper. I don't expect the rear to be a big problem in terms of caliper clearance but maybe someone could let me know if I would be better of running 295 or 305 with this rim setup and KW HAS on as well. "Will they fit" says using 305 will up a little tyre height (6mm) which is great because I worry a little about potholes and the condition of UK roads all together. Don't want to play with camber or see any rubbing. Any thoughts? Thanks |
