03-23-2020, 04:16 AM | #1 |
Rep 147
Battery charge
Morning
This long period locked in has got my M5 warning about battery discharge, can anyone tell me how long a ‘good run’ has to be to top the battery right up? |
03-23-2020, 04:16 PM | #4 |
Rep 147
I did a quick 40m, car seemed happy.
The roads were the way the were in about 1990. Virtually no traffic or queues, just a lot of dawdlers. Not sure how ‘recharging my m5 battery’ would fit as a need to go out after today necessity speech. |
M5Rick66632.00 |
03-24-2020, 12:20 PM | #6 |
Rep 1,847
I use this if its stood for more than a week, works perfectly
https://www.amazon.co.uk/CTEK-MXS-5-...s%2C220&sr=8-5 |
M5Rick66632.00 |
03-31-2020, 09:36 AM | #8 |
Rep 147
I did a long run today after the shop. The car has stopped asking and started telling it wants the battery charged. I will get a trickle when lockdown is over but (as it was the only reason I was on the motorway) I noticed the battery only displays as charging on efficientdynamics when the car is engine braking.
Is it genuinely not charging the battery under throttle? Why would ED specifically not show this...is this just some ED to try and make me think pressing the throttle is bad and not pressing the throttle is good. Not impressed. A battery charge remaining gauge would have been better than some ED graphical driver distraction. |
03-31-2020, 10:12 AM | #9 | |
Rep 1,847
03-31-2020, 10:40 AM | #10 | |
Rep 47
No issues with flat batteries. Also conditions the battery too. |
03-31-2020, 01:32 PM | #11 | |
Rep 147
I’m getting estimated times for delivery of 28 April from amazon |
04-01-2020, 03:48 AM | #12 | |
Rep 1,847
https://www.smarterchargers.co.uk/in...&product_id=53 https://www.halfords.com/motoring/ba...er-665079.html |
04-01-2020, 07:38 AM | #13 |
Rep 731
Hi guys I ordered this Monday, due for delivery today hopefully.
Like many others here I am getting the battery drain, dealers cant pin point the issue, had a new battery, starter motor etc, I can only out down to the tracker https://www.halfords.com/motoring/ba...er-230278.html |
04-04-2020, 01:19 PM | #16 |
Rep 731
By the way, does it matter if you opt for the lithium trickle charge over the AGM given that our cars have AGM batteries, you can perhaps sense I;ve dropped a boo boo
Thanks |
04-04-2020, 04:46 PM | #17 | |
Rep 47
Ctek say the following: There are many different types of car battery available today, including wet cell, calcium and Absorbed Glass Mat (AGM) . Each needs to be maintained in a slightly different way, but all of them can be charged and maintained with a CTEK 24V or 12V battery charger. For car batteries, a 12V battery charger such as the MXS 5.0 will charge and condition the battery through a series of stages. First it removes the sulphur from the internal plates, then breaks it down and mixes it back into the acid solution to give the battery a new lease of life. For trucks and other larger vehicles, CTEK’s 24V battery chargers will perform the same task. Wet cell, calcium and AGM are all different versions of the lead-acid battery, and have their own advantages, disadvantages and maintenance requirements. Wet cell car batteries, or flooded batteriesas they’re also known, still dominate a large part of the car battery market. The first wet cells were typically fragile glass containers with lead rods hanging from an open top. Now, developments in manufacturing techniques and safety have seen the wet cell progress to an affordable, reliable and – if recharged and maintained correctly – long lasting vehicle battery. Calcium batteries are also a big part of the battery market and have the same generic make up of wet cell batteries, except both the positive and negative plates are replaced by calcium alloy. This means that fluid loss is about 80% lower than a normal wet cell battery and the self discharge rate is also considerably lower, so there are huge advantages to these units. AGM – or ‘dry’ batteries – are the latest step in the evolution of lead-acid batteries. Instead of using water or a gel, an AGM uses a fibreglass separator to hold the electrolyte in place. Gel batteries use a gelified acid. Gel batteries can withstand deep discharging and are generally used in vehicles with demanding electrical equipment, electric wheelchairs and on boats. All of these batteries use different technologies to suit the different needs of the vehicle. But they all have one thing in common – they need to be carefully maintained to ensure they always provide the energy needed. None of them are free from self discharge so they’ll all require a charge at some point and a CTEK 24V or 12V battery charger will see to that. Unlike many battery chargers on the market, a CTEK 24V or 12V battery charger will react only to a battery’s specific needs, so every CTEK charger will charge, condition and prolong the life of all types of car battery. https://www.ctek.com/education/car-batteries |
04-07-2020, 09:59 AM | #18 |
Rep 147
Sorry, promise not to talk about batteries any more, I’m charged but probably not topped up......
......is this why my stop/start keeps showing a ‘system override’ (warm engine) and keeps the engine on at a stop? |
04-07-2020, 02:47 PM | #19 | |
Rep 47
I always override stop/start as I live in an area where traffic is light and stopping the engine for a few seconds is not likely to save much and is also very stressful on battery/starter motor etc. for little or no gain. |
04-09-2020, 05:53 AM | #20 | |
Rep 1,847
Plus as mentioned the fuel saving verses the wear on the starter motor makes no sense |
F10CPROG79.50 |
04-16-2020, 02:20 PM | #21 |
Rep 147
I’m probably stating the obvious here but I’ve trickle charged the car back to full....
...the stop start is back on but more surprisingly there seems to be a huge increase in power (either power or response etc), I’m talking about a 100bhp difference in feeling. I’ve read some threads, perception of improved power seems not unheard of but there’s no specific info. In the end I bought the charger I could get hold of during lockdown, aka a Halfords special. It’s not amazing but it’s getting the job done. Turns out everyone I know needs the thing. |
OneExtra798.00 |
04-17-2020, 03:22 AM | #22 | |
Rep 1,847
J11SEK269.50 |
