03-07-2023, 07:45 PM | #45 |
Rep 38
Are you able to provide more details about the installed ? If he has any contact details let me know . I heard from some people they do not work with the adaptive headlights I’m not sure if you are aware of that.
03-07-2023, 09:10 PM | #46 |
Rep 165
Your adaptive function will not work because those lights don’t have that option. Everything else will work just fine. You will need a harness and coding which Marius can do. About 4 of us have already did the conversion.
03-10-2023, 11:16 AM | #47 |
Rep 165
So just got off the phone with Marius, if you are xenon or pre LCI you will NEED the harness and coding to make it work. I miss understood him last time (French accent) 😸He meant if you have pre LCI and are installing OEM ikons then you don’t need the harness. For these aftermarket ikons YOU WILL NEED A HARNESS AND CODING. Hope this helps! I’ve had these on for a few months and so far all good. No leaks and it’s been rainy here quite a bit and even in low temps at 30-35 degrees it held up. Only thing I wished I did was install some PPF Wrap over the lenses before Installed it. Took a small rock chip on the way to vegas driving 100mph
03-10-2023, 04:39 PM | #48 | |
Rep 326
03-10-2023, 07:24 PM | #49 |
Rep 165
03-11-2023, 01:12 PM | #51 |
Rep 3,608
It looks like they have a plug and play xenon version as well (confirmed with seller, no adaptive function). As always, proceed with caution
https://m.facebook.com/photo/?fbid=5...50294963863279
Current: F80
Prior: F82, F32 |
03-15-2023, 08:05 AM | #52 |
Rep 14
DeezBluBallz161.50 |
03-15-2023, 08:16 PM | #53 |
Rep 165
You would have to ask Marius the guy who did the coding. Possibly he could make the harness so the pin position of the low and high beam different.
03-20-2023, 01:14 PM | #54 | |
Rep 165
03-23-2023, 12:17 AM | #56 |
Rep 837
Which CF splitter is that? Thanks
Current Ride 2020 M4 Competition/ Alpine White / DCT/ Full Black Leather / 19in Gunmetal / Executive /LED/Ohlinds RT/SSR DP-CP-Intake/AP Essex 9668/Bootmod STG 2/ VRSF DP
04-08-2023, 07:26 PM | #61 | |
Rep 1,387
If you compare your DRL's to actual OEM icons you'll notice they're different, especially the longer hexagonal shape, they're more drooped rather than round. If you look at the eyebrow section as well this is totally different to how the icons are designed.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
06-02-2023, 06:06 PM | #65 |
Rep 4
I just got mine installed and they look great definitely way better than xenons. My only complaint is that I wish the DRLs where brighter.
electricbrew19.50 |
