| 08-31-2014, 11:17 AM | #45 |
Rep 382
Thanks for sharing.
I love that aggressive look. Was a little worried about 12mm rear with the car lowered comp pkg. Looking at my car now with the 10mm the 12mm probably would fit without rubbing. |
| 08-31-2014, 09:27 PM | #46 |
Rep 1,839
My 601 on cp m5 are 10.5 rear.
I am eating my word and ordering 12mm to replace my 10mm rear. So I will have 12mm all around. I will let you know if I have any fit issues
| 08-31-2014, 09:46 PM | #47 |
Rep 382
| 10-05-2014, 02:58 PM | #48 | |
Rep 382
Any fitment issues or rubbing? |
| 10-05-2014, 03:53 PM | #49 |
Rep 1,839
@JPMD They just arrived, they were on a long back order! I will install them at the end of the month. I don't think I will have a issue but it will be close. I want to go 305, but may have to drop down to 10 mm again when I do that.
| 10-05-2014, 05:41 PM | #50 |
6'0 / 250lb
161
Rep 1,797
Not Comp pack... But 12mm on all four corners. Stock ride-height. No issues.
| 10-05-2014, 06:21 PM | #51 |
Rep 382
Nice; car really looks great
I did a few more measurements and 12mm rear with comp pkg should fit but might be a little tight Spinny will update us when he gets his done |
| 10-05-2014, 06:46 PM | #52 |
6'0 / 250lb
161
Rep 1,797
Something to consider. Since you
| 10-20-2014, 07:05 PM | #53 |
Rep 382
Guys, wanted to give you a quick update.
I still can report no real issues with the spacers expect I've noticed on some uneven roads and when there are cracks (both of which are not common here in South Florida) the car seems to track allot and this may be a result of the the larger front (12mm spacers). Soon I will switch the 10mm all around and report back. |
| 10-22-2014, 10:06 AM | #54 |
Rep 1,839
@JPMD 12mm WILL fit. My rear is a bit lower than stock and it fits, so it will definitely fit a stock CP w/601s. Its VERY close but no rubbing.
I am thinking about 305's for my next tire change. If thats the case i will need to go back to 10mm. 305's will not fit with 12mm. On other note..... 2 of my 601's are bent.... =(. So much for cast. ( thumbs up for all those that called it)
| Bookmarks |
