      08-12-2018, 04:10 PM   #1
BB6
Drives: M3 G80
DSS Axle Removal and Install
Guys, I threw a video on YouTube because I couldn't find one to remove and replace the Axles. I upgraded to DSS after I snapped mine and after I already had them removed I decided to do a video because there was no way I was going to do it the way ISTAD said to. Maybe I was wrong in doing so, but I figured out a way and thought since I couldn't find a video I would post one. Hope its informative and helps someone
https://www.youtube.com/watch?v=1_DK0zF4vAo&t=897s
0zF4vAo&t=897s
      08-17-2018, 07:30 AM   #2
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
This is a great DIY!!
      08-17-2018, 09:46 AM   #3
YanoM5
Drives: 2018 Individual Nardo M5
Thanks for the video. I just purchased a BM3 tune and will be adding downpipes. Did you just have the tune minus downpipes and you broke your axles? Was is it due to a lot to launches? I heard 91-93 ots tunes alone shouldn’t cause this.
      08-19-2018, 12:00 AM   #4
BB6
Drives: M3 G80
Thanks allmotor, you remember selling me your right side axle, I still have it laying around. Let me know if you want to buy it back. Haha
      08-19-2018, 12:04 AM   #5
BB6
Drives: M3 G80
I actually have the OTS 93 Stg2 and fabworks DP’s. Just broke them on a launch at the track. Got to be careful wif you have a tune, no hard launches on stock axles. At least that’s my experience. And I only launched the car maybe 5 times
      08-19-2018, 01:45 AM   #6
YanoM5
Aye scary! How were you launching? Launch control? I was just gonna slam the gas down at the track once the tree hit the 1 set of yellows!
      08-19-2018, 08:08 AM   #7
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Launch control is useless. If you're using mt streets then you'll break the axle. If you're on regular tires and you spin off the line then you'll most likely be ok. I did quite a few runs at the track with nittos nt05 and was fine. Once I put on the mt streets I snapped the left side axle on the 4th run.
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
      08-19-2018, 10:09 AM   #8
BB6
Drives: M3 G80
Yeah, I broke mine with 315 R888's on. They hooked extremely well at the track. I track is also very well prepped. This cars are not made for quarter mile, too heavy and the drive-train is weak. My brother has two zr1's and we have put those things through hell and they keep ticking. I love the M6 though. Great weekend warrior car.
Mcc420475.00
      08-20-2018, 04:30 AM   #9
allmotor_2000
1087
😆 I am sure someone will take it... put it for sale!
Now you need the diff mount. Check out my IG page: allmotor_2000
      01-01-2019, 04:42 PM   #10
AliG5436
Drives: 2018 BMW M3 F80 ZCP
Great write up and video! Just a little curious on how to removed the axles from the diff itself? Didn't quite see that in the video you posted! Do I just pull on the stock axle with all my might and they snap right out? or is there a special process?
      01-02-2019, 06:53 AM   #11
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
You need to put a flat screw driver to pry it out. There's a snap ring in the diff that holds the shafts in place.
Ig @mcc420
      01-02-2019, 09:35 AM   #12
BB6
Drives: M3 G80
i just used a prybar inserted against the bell housing of the axle closest to the diff. Take a piece of wood block to use it as leverage for the prying the axle off. You will have to bounce the prybar a little bit or maybe even a lot. I'm not a professional mechanic so do it at your own risk, but at least that's the way it worked for me.
      07-30-2023, 05:42 PM   #13
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
Great video; I sincerely appreciate the knowledge share.
Anyone have any long term use feedback on these?
