05-26-2020, 10:58 AM | #1 |
Rep 147
Brake pad wear mileage
My car is counting down in miles to ‘next service’ which seems to be the replacement of a set of brake pads.
Is this mileage countdown (now 1300) based on a countdown of the original number when the pads were replaced and the mileage counter was reset....or is this number based on some sort of measurement of the wear. I drive quite gently, is it possible I have a bonus few k in the pads? I’d like to try and delay it a bit and do it at the same time as tyres/mot. |
05-26-2020, 11:43 AM | #2 |
Rep 1,847
I think it takes the mileage into account but in reality the pads wont need changing unless they have worn down, the car may say change them but they will probably have loads of life. I would have a look and see how much pad material is left
msq12334.50 |
05-26-2020, 02:54 PM | #3 |
Rep 147
Thanks for this, do the pads squeal/ sensors throw up a warning before it gets dangerous?
05-26-2020, 04:38 PM | #4 | |
Rep 1,847
06-26-2020, 05:25 PM | #5 |
Rep 250
Mine kept telling me that I had 1400 miles left on the rear pads. Theres 8mm left on them, and will probably do 14000 miles. I watched a video on youtube on how to reset the warning, was so simple to do!
08-04-2020, 02:08 AM | #7 |
Rep 226
Has Anyone used a "less dust" pad on our cars when replacing pads??? The amount of brake dust that is thrown onto the alloys is ridiculous.....
I was thinking along the lines of these "redstuff" pads when mine are due....???? |
M5Rick60013.50 |
08-04-2020, 02:14 AM | #8 | |
Rep 19,524
I ceramic treat my wheels and the dust comes off with a water blast at wash time. |
J11SEK268.00 |
08-04-2020, 04:24 AM | #9 |
Rep 147
This is interesting, I checked mine again after the long run last week and I’m ‘stuck’ on 1400 too (not 1300). Mine were given a rudimentary check and apparently there is ‘loads left’.
08-04-2020, 04:30 AM | #10 |
Rep 37
I expect there is some sort of wear sensor but its too rudimentary to tell exactly how much is left and just knows when its low and needs changing and its just estimates and counts down to about 1400 and stays there till the sensor says it actually needs doing???
11-03-2020, 12:12 AM | #11 | |
Rep 147
Does anyone know how the system works? Is it a physical measure or just a timer? I’m not complaining, this is really quite nice (they ain’t cheap) but I like to be able to trust the countdown. I had a Honda once which passed its service, weeks later the pads completely wore through and the brakes went metal to metal writing the whole system off. Honda corporate told me that the main dealer had ‘nothing to do with them’ and then actually gave me some rude advice about where I should go. |
11-04-2020, 11:37 AM | #12 | |
Rep 107
They are defo much better in terms of dust and stopping. |
J11SEK268.00 |
11-04-2020, 11:41 AM | #13 | ||
Rep 107
Best to do a quick straw test and see how my mm u have left. If there is plenty then just watch on YouTube how to reset it. |
