04-15-2019, 05:56 PM | #3 |
Rep 533
[QUOTE=justm5;24652455]Air con doesn't seem to be working ! Not sure if it needs re gasing or there may be a problem? Any ideas[/QUOTE
Not blowing cold air, but otherwise operating? If so, could need a recharge or worse pulley or compressor. My pulley went out a few months ago, and there's no rebuild kit so the entire compressor was replaced.
1972 Bavaria> 1973 3.0Si> 2013 328i> 2009 E92 M3> 2013 F10 M5: Singapore Gray over Sakhir Orange, Executive, Driving Assistance, B&O
04-15-2019, 06:11 PM | #4 | |
Rep 7,885
[QUOTE=pcohen15;24658988]
04-16-2019, 01:47 AM | #5 |
Rep 533
[QUOTE=RPiM5;24659061]Extended warranty, thank you. Replaced A/C compressor with clutch. Reclaimed,evacuated, and refilled AC system. $965 parts, $1326 labor, total was $2291. I had it done along with a couple other warranty items, and I only pay one deductible per visit, not per item. So it either cost me $200 or nothing.
04-16-2019, 06:30 AM | #6 | |
Rep 7,885
[QUOTE=pcohen15;24660354]
04-16-2019, 07:03 AM | #7 |
Rep 606
The condensers are weak in this model. I would do a leak check first. Recharge the system and add dye. Wait a week (maybe less) and inspect the system as best as possible looking for leaks. Focus most attention around the condenser. Obviously if the shop hooks up their gauges and says the system is charged, you likely have another problem like the aforementioned compressor. Sometimes it can be as simple as a switch/sensor as well. I would make sure to get a proper diagnosis before writing off any common failures right away.
04-16-2019, 02:38 PM | #8 |
Jus530
Rep 10
04-16-2019, 04:39 PM | #9 |
Rep 201
04-16-2019, 05:01 PM | #10 | ||
Rep 533
[QUOTE=RPiM5;24660700]
04-16-2019, 05:06 PM | #11 | |||
Rep 7,885
[QUOTE=pcohen15;24663606]
04-17-2019, 06:37 PM | #12 | ||||
Rep 533
[QUOTE=RPiM5;24663640]
