04-18-2019, 09:01 AM | #2 |
Rep 606
Does the car exhibit any symptoms?
Record the code and clear it. See if it comes back. |
04-18-2019, 09:11 AM | #3 |
M Enthusiast
36
Rep 171
04-18-2019, 09:15 AM | #4 |
Rep 606
04-20-2019, 07:30 PM | #8 |
Rep 812
P0120 is a bad throttle position sensor (TPS)code . Sensor on the throttle body is reading out of range on bank A, compared to the other sensor on bank B. Sensor is probably just starting to go bad.
Formally known as BMWM3NYC
04-20-2019, 10:15 PM | #9 |
M Enthusiast
36
Rep 171
04-22-2019, 10:09 AM | #11 |
Rep 606
No DIY that I know of. You will have to find a copy of TIS or whatever they call it these days and see what the replacement procedure is. If it was me, I would replace them both. That's been my experience and "MO" on other BMW platforms with 2 banks of ITB's.
I believe the sensors are located towards the front of the engine, down lower where the intercoolers connect to the rest of the intake. For a visual, take a look at the technical update PDF on the S63TU located on this site |
04-22-2019, 11:26 AM | #12 | |
M Enthusiast
36
Rep 171
04-23-2019, 08:38 AM | #14 |
Rep 606
It looks like you have to replace the throttlebody assembly. Maybe in this case it's better to only replace the side that's failed!
http://www.realoem.com/bmw/enUS/show...diagId=13_0967 I think some guys that run meth have had to replace the TB due to wearing out the throttle plate. You might find some posts that could be helpful. I do think it is a lot of work to replace them. As I described in my earlier post, they are located lower on the front outer sides of the block. They might be best reached from under the car. I'm not positive. |
04-23-2019, 12:30 PM | #15 | |
M Enthusiast
36
Rep 171
04-24-2019, 10:53 AM | #16 | |
Rep 606
Please update the thread when you draw some conclusions! |
04-25-2019, 12:44 PM | #17 | |
M Enthusiast
36
Rep 171
9307A1 - Outside door handle electronics, driver's door: non-permissible current value on unlock line (this has been the case since i got the car, the comfort access lock/unlock doesn't work and the dealer had quoted me $400 to replace it but didn't think it was worth it) D02D3A - Camera-based driver support system (KAFAS) interface (camera, front area monitoring, 96.1.2): Signal invalid Could this really be a reason for a CEL though? |
04-25-2019, 11:32 PM | #18 |
Rep 631
None of those will set a CEL.
F06 M6 Grand Coupe CP
