04-22-2021, 03:15 PM | #1 |
Rep 147
Warming up
Hi/hallo/hej/howdy
What’s the best action upon first starting the M5? Some sources and threads suggest let it idle at standstill a short while, some specifically say as soon as the car is started gently drive away (I think this is the BMW line?) |
04-22-2021, 09:46 PM | #2 |
Rep 628
I wait for the cat heat-up cycle to end and the engine returns to low idle. That gives me time to fasten my seat belt, put my phone in the holder and put a smile on my face... and then gently drive off until the engine is up to temperature. My drive from home is a six mile drive at 40 and 45 MPH, which is plenty time to get up to operating temperature.
F06 M6 Grand Coupe CP
04-22-2021, 10:23 PM | #3 |
Rep 66
I usually start the car and go. Never put the car under any heavy load or over 3k rpm until I'm at operating temp. I have catless dp with cold start delete so I usually go right away. Otherwise I would totally wait till Rpms settle down to idle.
santamonica0070.00 |
04-22-2021, 11:48 PM | #4 |
Rep 538
Same as others for me too. I wait for the cat cycle and rpm to drop then I coast down the hill in neutral for another minute till I slap it in gear (3rd at ~20mph) and go on.
04-23-2021, 12:20 AM | #5 |
Lover of the 3rd pedal
70
Rep 103
Drives: '16 M5 6spd; '13 Audi S4 6 spd
Wait, what? I start the car and start driving. Should I be waiting? I live in Los Angeles so not sure because the temp doesn't get low I'm fine. Interested to hear from folks.
M5Rick59856.00 |
04-23-2021, 03:13 AM | #6 |
Rep 19,518
It's better to start and wait for a few minutes then proceed at low revs until the oil temp needle goes just past the first dot.
If you have an a/market exhaust with no cold start delete in a densely populated area you may have no choice but to drive off (neighbours) and take it easy driving it like a fiat 500 until up to temp. |
04-23-2021, 04:24 PM | #7 |
Rep 74
I usually let her idle until the cold start revs settle down. I'll let her sit for a few minutes idling then drive off gently. I won't go over 4K rpm until the needle starts moving. I rather take her gentle and let her warm up correctly before I get on her hard.
BMW Enthusiasts!
F10 M5 E36 M3 E70 X5M E90 335i XDrive M Sport BMW Performance Edition |
04-23-2021, 08:22 PM | #8 |
70
Rep 103
So I drove across "town" today in LA and my oil temp never hit the first dot. Still not sure what I'm missing here. I have a '16 F10 manual, stock other than Dinan coil overs. Teach me forum members!
04-24-2021, 03:12 AM | #9 |
Rep 19,518
04-24-2021, 01:40 PM | #10 |
Rep 193
I wait for cold start to finish, drive off for 2 miles and keep it under 3k since it's still cold when I get to work. When I'm taking a longer trip same except once it's up to temp I drive it like I stole it. (Tuned stage 2)
04-24-2021, 03:03 PM | #11 | |
70
Rep 103
M5Rick59856.00 |
04-24-2021, 04:08 PM | #12 |
Rep 19,518
04-24-2021, 05:02 PM | #13 |
Rep 648
I've heard it's best to keep the car in efficient mode rather than S3 as it will allow for quicker warmups.
04-25-2021, 10:39 AM | #14 | |
Rep 538
*It's like 101C instead of ~103C. Sport Plus, however, is significantly lower, being around 87-88C.
04-27-2021, 08:43 PM | #16 |
Rep 3,140
Drives: 2014 M5 6MT
30-60 second idle then low load till warmed up. Then it get the f@&king beans as much as possible.
2014 M5 6MT
04-28-2021, 07:10 AM | #17 |
Rep 687
Solo_M_Tech1687.50 |
04-28-2021, 08:29 AM | #18 |
Rep 606
With any modern vehicle, waiting beyond roughly 1 minute (enough to come down to normal idle as stated several times already) is just wasting energy. The engine will take a long time to warm up at idle. You want the car to go into closed loop and then start driving. As stated by others, be easy on the load until the oil warms up. IMO, once the needle is moving it's warm enough to drive harder if needed (like to pass someone) but I'd wait for any redline pulls until the oil is fully warm.
Regarding needle position for "warmed up", it definitely depends on climate and traffic conditions but you don't need to be to the first dot to be fully warmed up. Keep in mind that the gauge is "dampened" as well. My normal operating temp varies, but usually 3/4 of the way from "zero" and the first dot. It gets up to the first dot when in more traffic and/or stop and go. If you put into sport+ mode, the oil cooler is fully utilized which will bring the temp lower. |
M5Rick59856.00 |
04-28-2021, 05:51 PM | #19 |
Rep 191
I wait 3 seconds and go. I'll keep under 3k rpm for a while. Shift up manually at 1.5k or 1.7k. The default auto mode revs much more than I'm comfortable with. So I always override and do my own shifts.
I'll stay under 60 mph until the needle starts to move. After that I have fun. 128,715 miles. I took an e90 330i to 250,000 miles doing the same until the plastic fittings in the coolant lines started to break. |
05-01-2021, 12:17 AM | #21 |
Extruding Elements
513
Rep 539
Drives: 2016 BMW M5 Comp
This; mine is about a 40min drive with dropping off my son in there...plenty of time to press that little M button.
2022 Yukon XL AT4
2016 BMW M5 2015 Ford F250 Super Duty 2006 BMW M5 |
05-01-2021, 02:13 AM | #22 |
Rep 19,518
It's a big PU so it's not just a question of letting it warm up at idle but to get the oil circulating everywhere for at least two minutes before setting off.
