07-10-2014, 05:02 PM | #1 |
Rep 10
Top 10 Car Cleaning Mistakes
Hey guys,
So with the summer here and car season in full flight, here are my Top 10 Mistakes People Make When Cleaning Their Car. Let me know what you think! **Also, if the video was helpful, give it a “thumbs up” on YouTube (it helps me out, thanks)*** Also, I would like to hear any car cleaning mistakes you guys know of! |
07-10-2014, 09:49 PM | #3 |
Rep 8,942
My girlfriend scrubbed her entire car with a magic eraser. Discovered it when I waxed it and realized she had rubbed all the clear coat off.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
07-12-2014, 10:07 PM | #7 |
Rep 1,107
One to change/add: when drying after a wash use two waffle or micro-fiber style drying cloths. With the first cloth, fold it in quarter and lay it on the paint finish to dry it. Blot the finish, don't stroke it to dry it. Unfold it to expose a new surface as you move around the car. Once that cloth is too moist, switch to the second continuing to mostly blot the finish dry.
07-18-2014, 10:36 AM | #9 | |||
Rep 10
OUCH. For real? How bad was the paint after that?
Thanks! Thanks! Quote:
Thank you! |
07-18-2014, 12:52 PM | #10 |
Rep 8,942
It actually turned out ok. She had metallic paint and rubbed micro scratches all over everything. I used the armor all back to black 3 step kit after using a cleaner wax and followed it with 2 coats of gloss on top. The metallic paint helped a lot but from a few feet away it looks perfectly fine.
2022 Macan S
07-18-2014, 02:05 PM | #11 |
Rep 11,147
Good video that goes over the basics. Few comments:
1) it's perfectly fine to use a sponge. I use the Uber sponge from Detailers Domain and it's fantastic. 2) be sure to remove the tags form your microfibers. I see that you still have your tags on yours, and those aren't exactly soft 3) in your rinse bucket, you need a grit guard. Without the grid guard, the dirt particles don't sink to the bottom, which means you'll pick them right back up again |
07-20-2014, 09:03 AM | #13 |
Rep 444
For me, life's too short to worry about not using a soft-brush carwash but a great vid all the same - I really like the two bucket tip, I never thought of that.
On bird droppings tho apparently it's not the acid that does the damage after all: http://www.telegraph.co.uk/motoring/...-your-car.html |
07-20-2014, 10:35 AM | #14 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
One way to avoid the two bucket system is to use a handful of washing towel just once. I use 3-4 Microfiber sponges from top to bottom just once.
07-22-2014, 12:19 PM | #16 |
Rep 361
Not sure if this is an obvious one, but I've seen people wax their cards then vigorously wipe the was off. That's a no-no as you want to very lightly buff it with a micro-towel so the wax stays on the paint.
07-23-2014, 09:25 AM | #18 |
Rep 1,107
If you want to stay with one bucket for just rinsing and have more fun in the process (and who doesn't...) get a foam gun like this Gilmour Foamaster. The one in that link is the older version and has mostly brass construction, which I prefer to the newer plastic one. That's the cheapest price I can find for one.
For the past 3 years I've been using a Gilmour foam gun, with Optimum Car Wash soap and 2 microfiber wash mitts (one for lower section of car) from Chemical Guys and I'm getting the best results I've ever had. I've used microfiber wash mitts from Griots and others. They all look alike but the one I have from Chemical Guys is much more plush. And dousing your kid (and vice versa) with that foam gun is priceless. |
07-23-2014, 09:35 AM | #19 | |
Rep 6,696
Drives: F30 340i
07-23-2014, 09:38 AM | #21 |
Rep 11,147
Tags |
cleaning, detailing, scratches, waxing |
