      06-26-2019, 02:16 PM   #67
BeachM5nster
Drives: '14 M5
Originally Posted by Lowflight View Post
I put 10mm Berger on the back only. Any movement of the front setup looks awkward to me and creates more rock dusting. The 10mm on the rear created and even match all around.
i am still debating and i thought just 10mm on the rear would look beefy as the front wheels look fine in the fender, but when you look at the rear fender the rear wheels are inset too much and those are the only ones I really want to push out but unsure if it looks good without spacers on the front.
can you post pics?
      06-27-2019, 03:48 AM   #68
BeachM5nster
Drives: '14 M5
Originally Posted by M5theonlyone View Post
I would recommend just 5mm on the rears with 305's.Having spacers on the front may reduce your steering feel, too railwaytrackish.
i ended up putting h&r 12mm only on the rear. im not too keen on spacers on front wheels either.
looks great as i expected
M5Rick60050.50
      09-17-2019, 04:24 PM   #69
mgent
Drives: 2016 m5, 2014 Cayman S
Do you have to run extended lug bolts with the 12/10 spacer set-up?
      09-17-2019, 04:28 PM   #70
SapphireM5
SapphireM5's Avatar
711
Yes, I bought mine from BMS and they come with the longer wheel bolts.
Ickdeep5720.50
      09-18-2019, 04:59 PM   #71
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
Here is my setup. 12mm front with 10mm rears. Stock wheels and tire sizes
      09-21-2019, 09:17 AM   #72
thxbuff2001
Dictator for Life
thxbuff2001's Avatar
Drives: To many
Fits perfectly.
Ickdeep5720.50
      10-11-2019, 10:31 PM   #73
EMETREE
Drives: G05 X5 M50i
Here's my setup.
Lowered on KW V4. 15mm spacers all around. There is no rubbing in the front or the rear. I am on stock p zero tires 👍🏻
Bingly17.50
Ickdeep5720.50
      07-10-2020, 03:51 PM   #74
Passi-M5
Passi-M5's Avatar
Germany
59
Drives: M5 F10 Competition
Hello. it's been a year but you have pictures of 12mm behind?
      11-11-2020, 06:25 PM   #75
holengjuy
Drives: BMW M5
Here is 12mm before and after, car was lowered on H&R springs. Excuse the dirty car. 12mm is perfect in my opinion.
      11-13-2020, 07:45 AM   #76
co_pa
Drives: 23 m340ix
i have a couple sets of 12.5mm ecs spacers i used on my f80 m3. it looks like, from what i can tell looking at part #s on ecs.com, they would fit the f10 hub.
does anyone have experience transferring spacers from one platform to ours? if not, i will sell the 12.5s and go 10s all the way around.
edit: all my searching has me thinking the spacers and bolts are 1:1 between the f10 and f80. appreciate any thoughts or experience.
current: 23 g20 m340ix
previous: 2016 f10 m5 /// 2017 f80 m3 zcp /// 2004 e46 m3 zcp /// 2010 e90 335i msport
      11-26-2020, 01:25 PM   #77
J11SEK
J11SEK's Avatar
Drives: F10 M5 2015
12mm at the front
10mm at the rear....
Zero issues since fitted
Ickdeep5720.50
      11-29-2020, 11:24 PM   #78
hogpowr
Drives: BMW M5
guys, i have a 2016 M5 competition. 20x9.5 front and 20x10.5 rear OEM wheels. can someone verify what stock offset is on those wheels?
      04-24-2021, 08:51 PM   #79
some_idiot
Drives: 2013 singapore gray M5
any thoughts on brands? Macht Schnell, Burger, and Future Classics.
Do you really get more if you pay more?
      04-26-2021, 11:22 AM   #80
co_pa
Drives: 23 m340ix
i can only speak to h&r and ecs tuning as i've run those with zero issues on my bmws and audis. plenty of love in this thread for all of the brands listed. imho, i would not pay the premium for future classic to get a couple bolts and anti-seize paste. but that's just me.
ecs tuning 12.5mm on all for corners for me at the moment.
      06-26-2021, 02:34 AM   #81
Lord HUMUNGUS
Lord HUMUNGUS's Avatar
Drives: 14 M5 CP, 2002 Honda S2000
2014 with competition package, stock everything. 12mm macht schnell on all 4 corners. No rubbing issues at all.
Ickdeep5720.50
      07-21-2021, 08:43 PM   #82
M5Noob
M5Noob's Avatar
74
Drives: M5
2016 M5  [0.00]
I went Future Classic 12mm all around with FC 80mm titanium stud kit with Project Kics Neo Chrome open end lugs. A bit tunerish, but the Neo really works with roundel and gold CCB’s.
      10-02-2023, 01:18 PM   #83
Hellboy550i
Drives: BMW 550i
AM planning to assign the 12mm spacers in all 4 wheels for my F10 550i 2014, but before that should i have to use the spacers after alignment or before wheel alignment ..?
      10-02-2023, 01:55 PM   #84
M5_Brandoe
M5_Brandoe's Avatar
Drives: Black sapphire M5
It doesn’t matter.. you can do either or.
Instagram MRBrandoe
      10-02-2023, 10:02 PM   #85
Hellboy550i
Drives: BMW 550i
Thanks .. is it better to do wheel alignment in bmw dealer? Or outside ? Not sure if outside shops can do better or not ..
      10-03-2023, 02:24 PM   #86
co_pa
Drives: 23 m340ix
To be clear, you do not have to do an alignment to add spacers. Mount up and roll.
Dealer alignments are fine. Cost difference is negligible and they tend to take good/better care of our cars. They also tend only to align to factory-provided specs unless you are clear, and have a good relationship, with the SA.
If you have exact specs to hit, from a lowering kit or something, you should consider outside.
