06-24-2019, 10:37 AM | #1 |
Rep 88
Left steering gear after collision.
So I was told by a technician that I need a front left lower control arm, front left knuckle, and front left steering gear.
They said anytime there is a hard impact to the suspension that the steering gear (rack and pinion) must be replaced, because of the electronics involved. Is this true? Thanks for the help Last edited by roscopeeco; 06-24-2019 at 10:47 AM.. |
06-24-2019, 10:44 AM | #2 | |
Rep 19,524
06-24-2019, 10:49 AM | #3 |
Rep 88
He said that the part is 3,500, but I found one new online for 1,800. I wonder where he got the 3,500 from. Am I right in saying that the rack and pinion extend to both wheels ie (they are not separate pieces left and right.)
06-24-2019, 11:17 AM | #4 |
Rep 19,524
[QUOTE=roscopeeco;24950087]He said that the part is 3,500, but I found one new online for 1,800. I wonder where he got the 3,500 from. Am I right in saying that the rack and pinion extend to both wheels ie (they are not separate pieces left and right.)[/QUOTE
That's his profit I gather and just one rack, variable ratio, the middle teeth are spaced in more and the outer are more widely spaced being computer controlled. I gather if it's one side its just the tie rod and tie rod joints being replaced otherwise the whole rack would have to be done.The rack casing itself does not split from the left to right. |
06-24-2019, 11:26 AM | #5 |
Rep 88
I have the competition model. I have found two part numbers for it. One is 32102284867 and the other is 32102284987.
Both are listed for the competition package but look somewhat different. |
06-24-2019, 11:37 AM | #6 |
Rep 598
Isn't this impact covered by auto insurance?
06-24-2019, 12:08 PM | #8 |
Rep 19,524
Yes that's a new complete rack, not just the left side pieces.With that impact the rack mounting lugs have probably broken off.
06-24-2019, 12:15 PM | #9 |
Rep 19,524
BeachM5nster273.50 |
06-24-2019, 12:48 PM | #10 | |
Rep 88
I suppose the steering assembly has some electronic function that creates codes when there is something wrong with the suspension. |
06-24-2019, 12:56 PM | #11 | |
Rep 948
I doubt the steering ECU is able to detect an impact unless its fitted with impact sensors. To be sure and save yourself a large sum of money, I would have them carry out a diagnostic on the steering module and airbag module. If no faults are stored then have them change the damaged parts only. I run a garage and fully understand the concept, if this happened to me I would check everything over then replace the necessary parts only. |
OneExtra810.50 |
06-24-2019, 01:31 PM | #12 | |
Rep 88
06-24-2019, 01:38 PM | #13 |
Rep 948
Confused now, did he say to replace the assembly or necessary parts only?
06-24-2019, 01:54 PM | #14 | |
Rep 88
The guy in Milwaukee used to work for BMW and said 90% of the time they replaced the steering gear when they didn't have to. He said to replace only the damaged parts. He said that the dealership has been replacing the steering rack if a tire "was tapped". The place where my car is now quoted me 6.5k. The guy in Milwaukee told me 2.5k for everything but the steering rack. I am going to have it hauled to Milwaukee instead. |
06-24-2019, 09:24 PM | #16 |
Rep 88
Here are the codes it threw.
DYNAMIC STABILITY CONTROL (DSC) (DSC_25) 3 Faults D35A53 Signal (actual steering angle, front axle, 57.1.2) invalid, transmitter ICM/EPS D35A62 Signal (lateral acceleration, centre of gravity, 0X19A) invalid, transmitter ICM/EPS 480A02 ICM interface, steering angle, phase 2: signal invalid CAMERA BASED DRIVER ASSIST. SYSTEMS (KAFAS) (KAFAS20) 2 Faults E06C43 Signal (warning object coordination status, 0x21F) invalid, transmitter DSC /ICM E06C44 Signal (warning object coordination status, 0x21F) invalid, transmitter DSC /ICM SEAT MODULE, DRIVER (FAS) (FAS_12) 2 Faults 8029B6 Control, active seat ventilation, backrest: at least one fan in alarm status 802A1E No seat adjustment due to engine start condition INTEGRATED CHASSIS MANAGEMENT (ICMQL) (ICM_25) 2 Faults 48002C ICM, ACC: interface DSC 480128 ICM: steering angle implausible FOOTWELL MODULE (FRM) (FRM3) 2 Faults 030015 Power window, driver's door: no initialization 800F92 Welcome light, repeat interlock, active NIGHT VISION ELECTRONICS (NVE) (NIVI3) 1 fault DEEC16 Signal (object coordination status, 0x21F) invalid, transmitter NVE / ICM /DSC ELECTRONIC TRANSMISSION CONTROL (EGS) (DKG_10) 1 fault CF4008 DSC interface (qualifier function FDR, 0x173): Signal invalid CAR ACCESS SYSTEM (CAS) (CAS4_2) 1 fault 93076A Deactivation of terminal 15: upper startability limit reached, but deactivation preventer active CENTRAL GATEWAY MODULE (ZGW) (ZGW_01) 1 fault 801C10 Request reset terminal 30F due to unauthorized waking |
06-25-2019, 01:49 AM | #17 |
Rep 948
Some of the codes would already have been there more than likely and do not always indicate a fault. The steering angle codes however will clear and once a steering angle reset is carried out the car should he fine.
06-25-2019, 04:03 PM | #18 |
Rep 385
Once the battery starts getting low or has gone flat and then charged, you'll get codes from all kinds of modules. The shop will clear all those once they get to the point of the steering calibration reset.
06-25-2019, 10:29 PM | #19 |
Rep 541
