09-12-2020, 02:48 AM | #1 |
Rep 57
AFE Pro Dry S air filters or Drop-in filters
Hi,
Does anyone on here used this dry air filter set in their M5 F10? Please give me some feedbacks or reviews. Will this type of high-flow air filters mess up the air MAF sensors as some other filters on the market? Really appreciate it regards
TinTin
09-13-2020, 10:48 AM | #2 |
Rep 193
I have the afe dry filters, only issue I've notice is the erratic idle on cold start up which I'm not sure if I got after I installed them or had already. I haven't had any other problems as far as power goes, At 600+whp.
TinTin8889.50 |
09-13-2020, 11:07 AM | #3 |
Rep 1,254
I have them, no issues whatsoever. Slight increase in sound as well.
What I will tell is that I chose them because I heard of others going through MAF's due to the oil on oiled filters like K&N and BMC.
Cylenterok135.00 TinTin8889.50 |
09-14-2020, 06:44 AM | #4 |
Rep 606
A dry filter should always be chosen over the oiled filters out there. For the reasons stated. You WILL foul the MAF's over time with oiled filters.
09-15-2020, 09:00 AM | #6 | |
Rep 538
Under the assumption that the main risk is over-oiling, I've also mulled over putting the charcoal filters back in after re-oiling the K&Ns, doing a few hard pulls to get it sucking a lot of air through, then pulling the charcoal back out. Use them as a sort of "excess oil catcher". But I'm lazy and decided it wasn't worth it. Actually, another option is after oiling them to just blast them with my leaf blower, and then I wouldn't have to deal with taking the intake boxes out a second time. *though, comically, with the charcoal filters still in.
09-16-2020, 01:12 AM | #7 |
Rep 74
I have AFE Dry Filters and charcoal delete. No problems so far. I love the sound and slight throttle response increase.
BMW Enthusiasts!
F10 M5 E36 M3 E70 X5M E90 335i XDrive M Sport BMW Performance Edition |
09-16-2020, 06:33 AM | #8 | |
Rep 606
Regarding normal oil flow... the vapor coming out of the engine isn't being pulled through the sensor. It probably does play in role in why the sensors eventually need to be replaced though. On other BMW M engine platforms it's common to need to replace MAF's periodically for best performance. The sensor itself usually isn't degrading... it's getting contaminated. Most likely source for most of the contamination is oil vapor from the engine. |
09-16-2020, 08:09 AM | #9 | |
Rep 538
As some anecdotal evidence on the other side: I've ran a K&N on my Cobra (which has a MAF) for 15 years with no noticeable impact on the MAF.
technician117251.00 TinTin8889.50 |
