09-12-2020, 12:07 PM | #1 |
Rep 1,073
Need help with a Turbo Coolant Pump Issue
We have already replaced it with a new turbo coolant pump and I am still getting the Drivetrain Error codes on the car.
I have attached a copy of the ISTA codes and was hoping if someone could help me fix the issue? The shop owner said that it could be a module calibration issue with the replacement pump he said he have seen that happen before because the operation parameter feedback on updated components changes sometimes? Thank you so much.
09-13-2020, 07:00 AM | #2 |
Rep 606
I want to assume this was done, but just to be sure - did you/the shop check power, ground and continuity on that circuit? Those codes look like you have an issue in the harness potentially.
09-14-2020, 09:00 AM | #3 |
Rep 1,073
I just found out that there are 3 more pumps on the car one of them must be bad the only way to find out is to replace the remaining 3 pumps.
