09-20-2020, 02:39 PM | #1 |
Rep 250
Exhaust flaps constantly open and lack of power
Hi all!
A bit of background info first.... Bought my car in June, as soon as I got it home I wired the exhaust valves open. Recently I had catless downpipes fitted and a remap. Now catless I felt the exhaust was a touch loud, so decided to unwire the flaps so they work as BMW intended, with a view of fitting an aftermarket controller later. Now, as soon as I start the car, the valves open, even at idle. If I unplug the connector in the left side of the boot (trunk to some of you guys!!) behind the carpet, I hear a little whoosh of air and the valves close. When I plug it back in the valves open straight away. Alongside this, the car is down on power. With the downpipes fitted, and stage 2 map, it doesn't feel any faster than it did as standard (8.2 sec best 100-200kmh Dragy time). would I be right in thinking these may be linked? |
09-21-2020, 11:26 AM | #2 |
Rep 606
Maybe the tune has the flaps programmed to be open all the time. The vacuum they operate from comes from the pump that you disconnected the line from. It does not come from the engine. Your power issue is not likely linked to the exhaust flaps.
Have you scanned the DME's for codes? |
09-21-2020, 11:45 AM | #3 | |
Rep 3,140
Drives: 2014 M5 6MT
2. your power issue could be from a multitude of things from boost leaks to failing turbos to a leaking vacuum line or failing boost solenoid etc. Do smoke test on the car, both boost side and on the vacuum lines coming from the vacuum pump. 3. Post some codes please. 4. My 2014 M5 with factory downpipes and a flash tune made more wheel HP than a colleagues M5 ( catless downpipes DME tunings tune, Intakes and full exhaust) and it came down to a pair of failing turbos.
2014 M5 6MT
09-21-2020, 11:49 AM | #4 | |
Rep 250
09-21-2020, 11:50 AM | #5 | |
Rep 250
Thanks for the reply. There are no codes. And the flaps are open even once up to temp. |
09-21-2020, 09:15 PM | #7 |
Rep 3,140
Drives: 2014 M5 6MT
Put the car on a dyno. See what the WHP is. That will tell you if your tune is being applied correctly. I've seen a professional tuner load the stock file back into a car by accident and couldn't figure out why the car didn't make more power... to say it was hilarious is an understatement.
2014 M5 6MT
M5Rick59562.00 |
10-04-2020, 12:17 PM | #9 |
Rep 250
UPDATE!!!!!
Issue diagnosed! One of the wastegate actuators isn't holding vacuum, therefore, turbo not holding boost as it should. Couldn't find anywhere to supply a new actuator, so a used turbo has been acquired that I will take the actuator from. |
10-05-2020, 07:49 AM | #10 |
Rep 606
Glad you found the issue. Let us know that it has confirmed fixed the problem.
10-06-2020, 07:28 AM | #11 |
Rep 269
Glad to hear you found the issue. I have my flaps wired open as many others on the forum do. No loss of power just better sound.
