09-21-2020, 05:05 AM | #1 |
Rep 13
Crankcase fault code
I've randomly checked codes with Carly and have the following code pop up -
INFO 20E121 - crankcase ventilation 2 vent hose no connected/ defective. No CEL and car drives fine. Any suggestions? |
09-21-2020, 11:23 AM | #2 |
Rep 606
Clear it and continue living life. :-)
If you're curious, you could inspect the PCV hoses that go from the turbo inlet to the valvecovers. Read codes again after a week or so of driving (depending how often and how far you drive). |
09-22-2020, 06:36 AM | #4 |
Rep 606
Ah, that makes a difference then. Hmm. When you try to clear it, key on, engine off. Does it come right back even before starting the car? If so, it's a hard fault that must be related to a sensor somewhere.
