08-02-2018, 05:34 AM | #1 |
Rep 687
Heatsoak?
Even in 10-15dec c ambient temps i find after a few pulls the car doesnt pull as hard until driving a few minutes
I assume this is heatsoak? How effective are the bigger charge coolers or did someone figure out how tonincrease reservoir? Thanks |
08-04-2018, 11:37 PM | #2 | |
Rep 843
Also what mods do you have? |
08-05-2018, 07:48 AM | #4 |
Rep 608
It definitely helps. I'm using them running meth and on one run I see a drop of almost 20 degrees. Driving around in normal conditions the temps go up not on boost. But when meth is being used it drops faster than a 5$ h00ker .
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
08-05-2018, 12:32 PM | #6 |
Rep 843
Check out the CSF/Pure turbo IC for our cars. I have 4 meth bungs post IC and have seen AIT over 35 deg (with meth) on just a 3rd gear pull and keeps dropping. They help with heat soak.
I also added Motul's Mocool to my cooling system and that helped a bit. |
08-05-2018, 08:44 PM | #9 |
Rep 843
08-07-2018, 09:41 PM | #10 | |
Rep 966
Currently I have found none. People have installed them but where is the data showing cooling benefits. I have foil wrapped 2 sets of intercoolers with this product and thru datalogs with Mission Performance tuning; the stock intercoolers work perfect even thru track driving conditions here in CA https://www.ptpturboblankets.com/col...hermal-barrier |
RPiM52873.00 |
08-07-2018, 09:42 PM | #11 | |
Rep 966
Do you have some data showing this ? I have been searching and called vendors, seems no-one is posting information or I can not find it. Any input is greatly appreciated |
08-07-2018, 10:21 PM | #12 |
Rep 2,039
Datalogs with CSF and meth look good, no data on CSF by themselves that ive seen.
08-07-2018, 11:34 PM | #13 | |
Rep 966
I'll search more for CSF's posts. I am deff interested but need more proof other then "buy me" lol |
RPiM52873.00 |
08-08-2018, 07:25 AM | #14 |
Rep 53
Are the CSF intercoolers even readily available? I've done a quick search and it doesn't seem like there's a good stock of them
08-08-2018, 10:56 AM | #15 |
Rep 84
Here is a thread with a bunch of good info on the csf coolers. The last page has some logs too
CSF's new daily driver - Imola Red F10 M5 https://f10.m5post.com/forums/showthread.php?t=1455685 I'm personally not running them now but most likely will be in the future |
08-28-2018, 02:35 PM | #17 | |
Rep 504
@craze my car is tuned with catless downpipes.. feels great, and I don't use meth either - stage 2 Hex tune. |
pleong17.50 |
09-10-2018, 12:09 PM | #19 | ||
Rep 843
This is what I have posted "Quick 3-4 pull, shift early in 3rd and let off early in 4th. AIT drop 33deg! Post IC meth helps so much more with cooling." |
09-10-2018, 05:58 PM | #20 |
Rep 504
09-12-2018, 02:26 PM | #22 |
Rep 53
Are these available online now? Or do I need to call?
