03-19-2019, 12:59 PM | #1 |
Rep 948
Cooling fan
As you guys already know, the cooling fans on the m5 stay running for an additional few minutes after shutting the engine down. I understand this relates to engine temperature etc. In the past I am sure my cooling fan used to become active 90% of the time when the engine was turned off. Just recently I have hardly noticed it except for the odd occasion. The fan only seems to run on a slow speed setting when i do hear it. I will test the system if necessary but would just like to hear what other people have to say before i do.
Thanks |
03-19-2019, 02:05 PM | #2 | |
Rep 19,791
When switching off after some spirited driving though it comes on at a higher speed for a few minutes then a slower speed as it eventually goes off. |
03-19-2019, 02:24 PM | #3 |
Rep 948
That's how i would expect the system to work. I could have sworn it came on more often. Must have been in my head.
On a brighter note, I ordered myself some 5mm spacers. |
03-19-2019, 02:34 PM | #4 |
Rep 19,791
03-19-2019, 03:21 PM | #6 | |
Rep 541
info and a question
this is info from my bmw foreman: the fans are there so u dont have to idle for 5-10 mins to cool the turbos before shutoff for prolonged turbo life as you needed to do in older cars like supras, wrx, etc that didnt have turbo cooling fans. turbos want to be wet(oil) and cool. or theyll fry. BUT he said it is good practice to let thr car idle for 5 mins or so b4 shutoff in order to prolong the life of those fans ....- since him telling me that i always idle outside the garage for cooler air and more air than in the garage and i only get the low fan setting. and for only a few mins. i just watch my oil temp guage and when it drops as low as itll go and stays for a min, i shutoff. This is info ive gathered from this forum: the electric coolant pump wont run as long as needed after shutoff if your battery is below 80%(get a trickle charger and keep it juiced up for that reason alone) or it will cook in the lines and clog etc.. MY QUESTION about those spacers.. is 5mm what is needed for a flush fit on the stock 20s? front and back? will my fenders need to be rolled? and what brand spacers from where are the best? any performance downside? |
03-19-2019, 04:10 PM | #7 |
Rep 948
I went with 5mm spacers as I'm running 305 and 275 tyres. Some people use 10mm rear and 15mm front on standard tyre sizes. You won't need to roll your arches. I went with some cheapo Ebay ones. £35 per pair with extended bolts. Doesn't matter so much with the 5mm as they don't have the hub centre on them. When you go 10mm or more you are better off going more expensive like eibach or h&r.
03-19-2019, 10:06 PM | #8 | |
Rep 541
03-20-2019, 02:52 AM | #9 |
Rep 948
Tyre sizes are 305/30/20 and 275/35/20 Michelin PS4S. 305 offers a great improvement on traction, would definitely recommend. People recommend 275 with 305 for a few reasons that slip my mind at the moment. I.never noticed a problem when still running the 265s but got the 275 as they were actually cheaper. You don't have to run spacers with these tyre sizes, I'm doing it purely for looks.
BeachM5nster273.50 |
03-20-2019, 04:17 AM | #11 |
Drift Instructor @ BMW Club UAE
310
Rep 433
Drives: BMW F10 M5
Living in Dubai (Middle East) the cooling fan comes on every single time. In fact, I don't recall switching the car off and not hearing the cooling fan on.
F10 M5 - AlpineWhite/SakhirOrange[DCT](Current)
F16 X6 - SparklingStorm/CognacBlack (Current) Follow me on Instagram (Click) |
03-20-2019, 04:46 AM | #12 |
Rep 19,791
03-20-2019, 04:48 AM | #13 | |
310
Rep 433
Drives: BMW F10 M5
102,000 km And I'm on my second Battery. I daily drive my car so I don't worry much about battery
03-20-2019, 05:08 AM | #15 | |
Rep 19,791
The other thing I'm itching to ask is how often you change your air filters. |
03-20-2019, 05:12 AM | #16 | ||
310
Rep 433
Drives: BMW F10 M5
I recently bought BMC aftermarket filters just to get a tad bit of extra air flow
M5Rick60879.50 |
03-20-2019, 05:26 AM | #17 | |
Rep 19,791
03-20-2019, 05:42 AM | #18 |
310
Rep 433
Drives: BMW F10 M5
Thank you sir!
I'm actually an Engineer. Being a drift instructor is a voluntarily thing that I do with BMW Club UAE. It's not something I get paid for, it's pure joy
03-20-2019, 08:16 AM | #19 |
Rep 606
I can add another data point that my fans kick on after shut down 95% of the time, even in winter with cooler oil temp. They run on low and not for very long. I typically idle the engine for 1-2 minutes before shutting down when I have the convenience. I daily drive including while working, so I don't always have the time to sit there and idle. That said, the oil temps are always low when in this mode of driving... below the first dot.
Keeping the double thread theme going, I'm considering 305's in the rear for my summer tires (currently on winter Pirelli's). Sounds like people are recommending 275's in the front? Any noticeable drop in gas mileage or difference in daily handling? |
03-20-2019, 08:50 AM | #20 | |
Rep 948
03-21-2019, 03:18 PM | #21 |
Rep 948
I tried to actuate the cooling fans using our snap on machine but didn't have the option available to do so. I ran the battery test using the snap on via the Intelligent Battery Sensor. It showed that the battery was at around 60% and should be charged. The car is my daily driver so I cannot see this fixing my issue. Does anybody know the battery percentage allowed before things like start stop and the engine off cooling fan to be deactivated? I have noticed for a while now that the start stop will not function for maybe a week then one day will work on every stop for one journey then maybe not see it again for another week. I assume this is also related to battery strength.
03-22-2019, 02:36 AM | #22 | |
Rep 541
and yea i want the looks too |
