08-11-2021, 11:44 PM | #1 |
Rep 392
Drives: F13 M6
TPMS question — Constant light
F13 M6 here. TPMS malfunction light came on. Im seeing all 4 wheels as yellow. When I try to go to reset tpms its greyed out and I can do anything. This happend on a long road trip.
The car is a Canadian model, so wanna check with you guys for tpms details. I had coded the car with carly and I think I attempted to add the temp and psi readings to the car. Then later on a road trip, the light came on. I had been driving for some time, but i have not ever seen temp and psi displays previously. Also never had any tpms lights appear. I have scanned with ista, protool, and carly. No tpms error there, but the car displays the light and in vehicle status it informs of a low tire. Again it wont let me reset it. The tires are adequately filled. Also oddly enough, my valve stems arent metal they are rubber. Do Canadian models have tpms??? I cant find the RDC unit listed in the list of control units for the vehicle….???? Im going to start with coding those features off. ( temp and psi for tires / display). Im going to be doing some other services soon. So would like to handle this while that is happening. Any suggestions would be appreciated. |
08-12-2021, 08:43 PM | #2 | |
Rep 1,245
08-12-2021, 08:49 PM | #3 |
Rep 392
Drives: F13 M6
I thought that might be the case lol. The tpms is an optional addon in Canadian market???
08-12-2021, 08:59 PM | #4 |
Rep 392
Drives: F13 M6
I tried doing the shut off tpms coding in the khombi and light still came back. Ill check into the coding more this week. Hopefully, I get this sorted.
08-18-2021, 10:57 PM | #5 |
Rep 1,245
Defiantly you didn't code them out completely
08-22-2021, 08:22 PM | #6 |
Rep 392
Drives: F13 M6
Okay I will try coding it out tomorrow. Thanks for the suggestions. Do you have any advice in which things to code off on carly or protool.
08-31-2021, 08:19 PM | #7 |
Rep 392
Drives: F13 M6
So I coded off the tpms settings in the khombi and in another module. The FTM works, so does the tpms. The reset button was no longer greyed out. I reset it and all good. So for anyone reading this. Make sure you check coding carefully before doing it.
