      12-29-2015, 10:01 PM   #1
46m3csl
Drives: 335i
What to know before buying the f10 M5
Hello guys I currently have a opportunity to buy a 2014 F10 M5 compitition package at a good deal. What some of the know issues about the car? How has yours been since purchase? Any major problems?
      12-29-2015, 10:42 PM   #2
cassidysdad
i have a 2014 zcp
no problems so far
what dealer are you using?
      12-30-2015, 01:15 AM   #3
46m3csl
Drives: 335i
Its through a private dealer, has about 30,000 miles on it though, probabky can get it for 66,000 with every avaible package on it? What do you guys think?
      12-30-2015, 02:04 AM   #4
Scott@Radar-Mirror.com
Scott@Radar-Mirror.com's Avatar
79
Drives: 2016 BMW 550i
I don't personally know enough about the used F10 values to comment on your specific find but I've owned several M5's, similarly priced AMG's etc and if I were going to purchase one of these cars used I would want to find a CPO car or try to negotiate an extended warranty in to the deal, especially if you plan on keeping it for a while. Good luck.
      12-30-2015, 03:35 PM   #5
HappyMan
Drives: 2015 M5
M5 was my dream car. I bought 2015 M5 and now I don't know what to feel and what to do. Reason is suspension. Through bad roads ( not potholes) fronts suspension makes noises and you feel as if shocks or lever arms or other details of front suspension is broke, faulty or loose. Dealer checked the whole suspension and says everything is ok and its normal. How can it be normal it's disgusting it feels like car had millions of km passed through worst roads in the world. I asked here on this board and it seems that no one have this kind of problem.
Guys please help me out here.
      12-30-2015, 04:02 PM   #6
Mbdurham17
Mbdurham17's Avatar
162
Drives: 2016 M5 CP
I've had my 14 ZCP since new and after 32000 miles and I've had zero problems or issues other than a cracked windshield and finding tires
      12-30-2015, 07:13 PM   #7
46m3csl
Drives: 335i
Good to know you guys are not report all sorts of issues with the car, anyone above 50,000 would be nice if they could chime in.
Thanks
      12-30-2015, 09:37 PM   #8
Bluehorseshoe
Bluehorseshoe's Avatar
307
Drives: M5 CS
All options? Seems like a great deal as long as the car is in good shape. Get it checked out at local BMW dealer. They will charge you less than $200 for inspection.
Just think you're getting almost 50 percent off MSRP. And you will get another couple years warranty unless you hit 50k miles first.
      12-31-2015, 02:02 PM   #9
46m3csl
Drives: 335i
Thanks for the input Guys, is the zcp worth it?
      01-04-2016, 12:37 AM   #10
Sergm3
Drives: 2014 f10 m5 comp
I'll be taking mine next week for same problem. I'll let you know what they find.
      01-04-2016, 01:46 AM   #11
HappyMan
Drives: 2015 M5
Wow at last, thanks
      01-05-2016, 10:46 PM   #12
Sergm3
Wow at last, thanks
Got a call from dealer today my suspension noise turns out to be from broken engine mounts. Hope it help with your suspension noises. My car has 14000 miles.
      01-05-2016, 11:27 PM   #13
HappyMan
Drives: 2015 M5
Wow at last, thanks
What kind of noise you had?
Can someone suggest the best way to show or explain the noises of suspension i have?
      01-07-2016, 05:42 PM   #14
sonnenschein3000
Drives: 2015 M5 (F10 LCI)
I don't know about USA cars, but in the UK, the M5 should have definitely had its run-in service at around 1200 miles or so. This makes the car's warranty valid.
Other than that, check for signs of abuse and mis-use, does it sound OK when you drive it? Turn the audio off, put the windows down and drive it along a quiet road and hear for any 'rubbing' or whining noises. Press the accelerator gently to accelerate, and then lift off and see if you can hear anything unexpected?
That's what I did when I got my 2013 M5 used.
      01-09-2016, 09:02 AM   #15
soooma
///MD
soooma's Avatar
Drives: M5 F90
Good deal go for it
Get it to be certified though
And in reply to the other member about horrid front suspension, it can be jarring at times but not that bad man !!
      03-13-2016, 06:25 PM   #16
M5Beast_NYC
Drives: 15 M5
Did you end up purchasing it??
      03-13-2016, 10:18 PM   #17
46m3csl
Drives: 335i
No I actually didn't, it sold before I could get one. Other than that have not yet found one with the competition package and the B&A system. If I do find one its way over priced.
