      10-30-2014, 09:05 AM   #1
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Drives: BMW 2017 M2 07/16 Build
Led Reverse Lights With no IDrive error or resistor
Here's a small write up I couldn't really find anything on the F10 Series. I found some info on f30.bimmerpost.com and I went and tested it out to see if it works on F10's and it does.
Lights I bought for reverse are
http://www.ebay.com/itm/161384748580...%3AMEBIDX%3AIT
They work really well and are very bright the top light is magnified so it projects out more.
My car is a 2014 M5 but lights should be the same on all F10's
Installing of the Led's is easy you just need to remove the trunk cover which is held by plastic screws. 10mins to remove.
You will need to Code two items in the FRM Module to stop the drive error.
AUSG_24_RFS_L_IS_LED to aktiv
AUSG_25_RFS_R_IS_LED to aktiv
This seems to tell the car the bulb is LED and doesn't pop any errors in the Idrive also stops the flickering of the LED if you do get this but I didn't.
I have attached a picture the LED working also the other file is reference from F30 but they are similar for the F10 also.
      11-03-2014, 06:25 PM   #2
M5 Power
Drives: 2014 M5 F10 CP
Thanks for the info
I have a 2014 M5 changed all the lights to LED except the reverse light
Your link seems to be broken, can you pls send me the LED bulb info
neil.anandarajah@bell.net
      11-04-2014, 07:27 AM   #3
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Originally Posted by M5 Power View Post
Thanks for the info
try this one
http://www.ebay.com/itm/2pcs-High-Po...47d624&vxp=mtr
      11-04-2014, 09:14 AM   #4
M5 Power
Thanks Jimmy, I just ordered them
Cheers
      08-24-2015, 06:14 AM   #5
tekaefixe
tekaefixe's Avatar
Switzerland
Drives: BMW M5 DCT CP PureMetalSilver
Jimmi do these reverse LEDs also work in LCI models?
      04-08-2016, 06:33 AM   #6
taohunoi
Drives: 640d gc
I use 6 series 640d f06 gran coupe .I would like to confirm that code can use for my car also I think f12 f13 its can use also thank you so much....Tawita from Thailand
      03-11-2021, 06:22 PM   #7
NZ-M340ixDrive
New Zealand
27
Drives: 2020 M340i xDrive
reigniting ahold thread but can you specify the led type as the thread is broken due to the age
Thanks again
335i DCT - Sold
M5 DCT - Sold
M140i Top mount big single - RIP
M340i xDrive Top Mount big single in the works
