      10-13-2019, 02:22 PM   #1
OneExtra
OneExtra's Avatar
Drives: None
Coolant Level Question
Just opened the coolant cap and I could not see any coolant the car has not said to add any coolant so I was wondering where the min and max levels were as I couldn’t see any?
      10-13-2019, 03:03 PM   #2
Dwaynos
Dwaynos's Avatar
If you're referring to the main coolant bottle on the right side of the engine bay (when facing the car) then to my knowledge there isn't a visible min max indication. If you shine a torch down the neck you should see the coolant at the bottom.
That's how mine is anyway.
OneExtra810.50
      10-13-2019, 05:00 PM   #3
OneExtra
OneExtra's Avatar
Drives: None
Many thanks that’s the one
      10-14-2019, 07:45 AM   #4
OneExtra
OneExtra's Avatar
Drives: None
Just checked again and its right at the bottom of the tube so all good
      10-18-2019, 09:16 AM   #5
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
I read somewhere that you have to use a tape measure and make sure it's within 4-5"?? from the top. Once you do that a couple times you will get to know what the level should look like without measuring. Don't quote me on the 4-5". I haven't verified the number in a while.
OneExtra810.50
      11-13-2019, 04:16 PM   #6
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
👌🏻👌🏻👌🏻 Correct. We have in cm but 18cm down on neck and tape should be coolant.
      11-19-2019, 06:18 PM   #7
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
Car also won’t alert you when this is low as far as I remember
OneExtra810.50
      11-25-2019, 03:05 PM   #8
TLK
TLK's Avatar
112
I use a tape measure set to 6" which was about the same as the metric spec in the TIS diagram.
OneExtra810.50
