04-21-2020, 12:00 PM | #1 |
Rep 175
Spark plugs for a Stage 1 tune?
I have a Comp Pack M5 with catless downpipes. I'm about to install a Stage 1 tune - about 710hp and 650 ft pound of torque at the flywheel - not sure what that would translate to at the wheels.
There seem to be conflicting views on whether one should fit one step colder plugs, simply re-gap the stock plugs, or just leave the stock plugs as is without re-gapping them. I'd appreciate input on this from those in the know. If one step colder is recommended, please advise which plugs. If re-gapping the stock plugs is recommended, please provide the specs. |
04-21-2020, 12:17 PM | #2 | |
Rep 948
I went with NGK 95770 I think, 1 step colder, gapped them to .018 and all is well. |
04-21-2020, 03:57 PM | #5 |
Rep 175
Thanks. Any idea if 1 step colder plugs will cause problems if I'm running the stock tune? I ask because I plan on having the stock map run on Comfort mode (to accommodate for our crappy fuel) and the tuned map on Sport and SportPlus (which I'll use when adding octane booster)
04-21-2020, 04:27 PM | #6 | |
Rep 948
04-28-2020, 09:24 PM | #7 |
Rep 15
How much e85 can we run with the stock fuel system?
Exotic Cars & Coffee Louisville KY, 2011 M3 DCT 43K E93, 2014 X3 3.5i xdrive MHD Ceramic DP VRSF, Sold E93 335i, Sold, E90 335i, Sold M roadster, Sold 330i msport, Sold E60 08 V10 M5, Sold E90 335i, F10 BMW M5
04-28-2020, 10:28 PM | #8 |
Rep 646
@GreenRacingM3 I run anywhere from 3-4 gallons. Never more than 4.
I also don't run E85 all the time. Usually every 2-3rd fill up depending how spirited I plan on running. There's a thread on the forum that gets more detailed into the numbers. A quick search should pull up all the information you need. |
05-10-2020, 09:57 PM | #9 | |
Rep 368
05-10-2020, 10:48 PM | #10 |
Rep 175
Efficient mode - the default mode on start-up - engages a more conservative tune (closer to the stock map). Engaging the Sport (M1 button) and SportPlus (M2 button) modes will automatically activate the Stage 1 tune. I decided to use the one step colder NGK plugs, gapped them to 0.023 and so far no misfires when running in either Efficient or SportPlus
05-12-2020, 07:42 PM | #11 | |
Rep 368
05-12-2020, 10:49 PM | #12 |
Rep 175
None. I asked the tuner from whom I bought the stage 1 tune to ensure that the map he sent me would leave the car at stock power levels in Efficient mode and bump the power up to Stage 1 level in Sport and SportPlus. I don't know how he did this but I'd imagine any tuner who knows this platform well can.
05-13-2020, 09:07 AM | #13 | |
Rep 368
05-13-2020, 02:36 PM | #14 |
Rep 175
Evolve - UK based. Very helpful guys and loads of experience with this platform. SportPlus map is dialed in nicely. No dyno numbers but the gains are tangible, the power delivery is smooth and the data logs look spot on. They're in the process of sorting the Efficient mode map
05-13-2020, 08:55 PM | #15 | |
Rep 368
Ahh okay, yep im familiar. They were big in the E46 M scene |
