04-27-2020, 11:45 AM | #1 |
Rep 8
Catless Lambda Sensors
Hi All. I'm going to fit de-cat pipes to the F10 next week and whilst i'm at it change the Lambda sensors to potentially rule out another issue. Might be a stupid question, but are the lambda sensors before and after the cat the same part number and where's the best place to buy them from? Also the best place to get hold of the 90 degree spacers too to get this all to dit. Thanks,T
04-27-2020, 12:23 PM | #2 | |
Rep 948
Check out realoem for the part numbers then do a google search for them. You shouldn't need the 90 degree adaptors if the downpipes you are fitting are good quality. Don't bother with the cat emulator adapters as they are junk. I assume you're going to be tuning the car? |
04-27-2020, 12:40 PM | #3 | ||
Rep 8
04-27-2020, 12:57 PM | #4 |
Rep 948
There is fouling but only when the downpipes aren't made properly and the sensor holes are in the wrong place.
