      08-21-2017, 07:56 AM   #1
Lennon997
Drives: f10 m5
delete
pls delete
      08-22-2017, 04:55 PM   #2
v3n0m
Drives: 2013 MCB M5
Originally Posted by Lennon997 View Post
nobody? this forum sucks
Classy.
      08-22-2017, 08:10 PM   #3
josec70
josec70's Avatar
Like that? Nice.
      08-23-2017, 11:39 PM   #4
v3n0m
Drives: 2013 MCB M5
Originally Posted by v3n0m View Post
Classy.
yea, e46fanatics gets more traction and thata a 12+ year old platform, but 10,000 people will respond to a 'which exhaust is better thread'.
Perhaps it's because the f10 is still a relatively new platform and nobody's had the same problem (and with a small % of people upgrading to an LCI wheel)? And the fact the e46 is much older so others have likely experienced or solved most problems people bring up?
Nope. It must be because the forum and everyone here sucks. *sarcasm*
Why don't you figure what's wrong and contribute rather than assume nobody wants to help.
      09-21-2017, 04:37 PM   #5
UnfoundLegend
UnfoundLegend's Avatar
Drives: '14 F13 M6 Coupe
It needs to be coded out yes. It's the paddle shifters that cause the problem IIRC.
      09-22-2017, 09:18 AM   #6
Lennon997
Drives: f10 m5
Resolution!
Ended up being a clock spring......the entire car had to be updated for this one part.....lost all my coding, my tune, etc. but was covered.
      09-22-2017, 01:59 PM   #7
UnfoundLegend
I also lost my coding and tune when my software was updated for an emergency call malfunction. It was updated to the latest software and now the tune is incompatible. Going on 9 months without a proper working car...
You must have had a one off problem because all steering wheel retrofits eventually need to be coded to work properly.
      09-22-2017, 02:38 PM   #8
v3n0m
Drives: 2013 MCB M5
That?s not true. I have a retrofit. No coding necessary and all functions work.
      09-22-2017, 03:04 PM   #9
UnfoundLegend
http://f10.m5post.com/forums/showthread.php?t=908738
Sometimes the circuit that is checked by the SZL and EPS modules require a deactivation, adaptation, or an update to work/respond correctly when doing retrofits or tune flashes. I've run across the problem. It's not common but it does happen.
ex. when retrofitting LCI taillights, the LED shows a fault code until the module speciifcation is set to nicht_active to deactivate the check.
      09-22-2017, 04:45 PM   #10
epiphanyray
Drives: 2003 E39 M5 + 2013 F10 M5
I second this. No coding necessary. Just took off old steering wheel, and replaced it with new lci.
