07-08-2014, 02:24 AM | #1 |
Rep 1,576
Upgraded intercooler
My car heats up alot when it is driven hard. Sometimes it writes, oil temperature too high, please drive slowly, it turns the car automaticall to D1.
I was wondering if there was an upgraded intercooler for this. Anyone else had this happen to them? |
07-08-2014, 02:55 AM | #2 |
Rep 222
Although this hasn't happen to me, have you checked to make sure your oil cooler is clean and free of bugs/debris? Also what weight of oil are ya running?
07-08-2014, 03:11 AM | #3 |
Rep 792
Do you still have cats or catless?
07-08-2014, 04:28 AM | #4 |
Rep 1,576
Car is completely stock. If I am not mistaken, the oil which I get from the bmw dealership is 0W40. It gets pretty warm in the summer (30 degrees C) and I drive very hard. Also, The car is mostly driven on mountains which might also be another cause (uphills)
07-08-2014, 04:52 AM | #5 |
Rep 222
Sometime when I wash the car and let water run through the inter coolers & oil cooler I get a lot of bugs out of there. I am not hard with the spray just soak it down good and let water flow through it. There is a thermostat on the oil cooler that should be opening and may have failed but no one else has reported this.. I too have driven the car hard on 30-35C+ days pretty damn hard and never had an overheat. Check for plastic bag/debris on bottom of oil cooler. The oil cooler is the one that runs parallel to the ground on the bottom of the center opening in the front bumper.
07-08-2014, 05:01 AM | #6 |
Rep 1,576
The car is cleaned every week and detailed every couple of months. I don't believe that this is the issue. The tarmac here in leb is very soft, so the wheels keep spinning, and it is an uphill.. That also might be a reason.. Any way to upgrade the oil cooler?
07-08-2014, 05:44 AM | #7 |
Rep 222
That wouldn't be an easy proposition to upgrade the oil cooler within the space constraints. Washing the exterior of the car is not going to keep bugs and crap from hitting the underside of the oil cooler. Think of it as a radiator that is 4 inches above the ground with no real guard on it. If you look under your front bumper you will see it there. Just have a look should be a dull grey painted color. These cars are pushed hard in the southern USA and west coast and are not overheating in this manner. There must be a mechanical/physical problem present.
07-08-2014, 05:47 AM | #8 |
Rep 222
Check out this blog entry to see what I am talking about. http://m5carblog.blogspot.ca/2013/02...brication.html < Normal car washing would not clean this if it has debris on it.
07-08-2014, 06:03 AM | #9 | |
Rep 1,576
07-08-2014, 06:06 AM | #10 |
Rep 222
Damn! You could by a small car for the price of the tires alone! Have you been taking drifting lessons from Jeremy Clarkson?
07-08-2014, 07:13 AM | #11 | |
Rep 792
I guess if I take it to a road course that will probably be comparable to the way you're driving lol. Well good luck hope you get it resolved. |
07-08-2014, 07:24 PM | #12 | |
Rep 664
How many miles do you have on the engine ? |
07-09-2014, 12:23 AM | #13 | |
Rep 4,204
How do run water through the intercoolers if we have water to air IC's?
Current: 21 M5 Comp, 23 M3 6spd, 24 iX M60, 23 i4, 20 Tundra TRD PRO
07-09-2014, 12:41 AM | #14 | |
Rep 6,274
What temperature your oil gage shows normally?
Gone : 2020 F92 Black Sapphire M8 - ZF8 Gone : 2018 F80 Mineral Gray M3 Competition - 6MT Gone : 2016 F82 Austin Yellow M4 Competition - 6MT Gone : 2013 F13 Sakhir Orange M6 -7DCT |
07-09-2014, 12:55 AM | #15 |
Rep 611
I think he mean by other cooler which there are a few more around the bumper side not the water to air intercooler.
2014 M6 GRAN COUPE FULL HAMANN WIDEBODY.
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19 |
07-09-2014, 01:46 AM | #17 |
Rep 222
I am referring to cleaning bugs and crap out of the air side of the inter-coolers. I just use a garden hose no crazy pressure. No the OP was talking about overheating. If the I/C and O/C are flowing freely (on both sides) the car shouldn't be overheating if you are moving at speed getting lots of air through them.
07-09-2014, 08:23 AM | #18 | ||
Rep 1,576
I add a quart of oil every 600-800 miles. i have a quart in my trunk at all times. Never drive it hard while warming up. once the oil reaches the quarter mark, then I start driving hard. During a hot early morning Sunday ride, it will go over 120 degrees C relatively quickly, and then I try and cool it down for a while, the fact that I am spinning wheels alot might be a cause as well. |
07-22-2014, 04:44 PM | #19 |
Rep 785
I think he means cleaning the heat exchanger not the intercooler.
991 Turbo
993 GT2 Outlaw |
07-29-2014, 06:17 AM | #20 |
Rep 12
Answering your question:
http://www.ecstuning.com/BMW-F10-M5-S63_4.4L/ES2764082/ |
07-29-2014, 09:28 AM | #21 | |
Rep 222
10-17-2014, 09:19 AM | #22 | |
Rep 1,576
