      11-25-2015, 03:32 PM   #1
drbru
Drives: f10 m5
Rear TV screens
I'm looking to add some form of rear tv screens to my f10 m5 and Im currently not considering the iPad option etc...
Basically, because I've got a real good opportunity to buy the genuine BMW screens (2014) version really really cheap and all I need to do is to figure out how to install them so I have a couple of questions for those in the know
1) How will they actual work - are they hard wired to the unit up front and controlled by that?
2) Does the sound come out through main speakers
3) How much approx would BMW charge to do this kind of retrofit if I am supplying the parts
Thanks
Bru
      11-29-2015, 08:45 AM   #2
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
Thanks
Bru
I have the stock Rear Seat Entertainment system and they are both wired to the RSE-NBT unit which is in the center console. It's basically another NBT navigation system built into the lower back center console.
So you would need to retrofit that unit along with all the wiring.
      11-30-2015, 10:20 AM   #3
drbru
Drives: f10 m5
So that sounds complicated to do and expensive!
      12-01-2015, 11:17 AM   #4
johntomferg
Cheaper / Better alternative may be to just get some iPADs and the holder. Plus you can use them when not in the car!
      12-01-2015, 03:55 PM   #5
drbru
Drives: f10 m5
My only issue with that is that it just looks bolted on as opposed to a factory option
Anyways, doesn't look like I can do it anyway as BMW have told me its not possible
      12-01-2015, 08:27 PM   #6
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
It's always possible... The real question is do you want to spend the money to make it happen.
BMW says retrofitting NBT's into E-series vehicles is impossible, yet it's dome every day.
      12-02-2015, 07:10 AM   #7
drbru
Drives: f10 m5
I think your right..Lets assume its not too expensive and I want to do the work...Im not sure I could get a BMW dealer to do the work...
Im sure an audio shop would be willing to do the work but it would then invalidate my warranty
      12-02-2015, 10:43 AM   #8
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
They could, really depends on your dealer. As long as it was done with all OEM parts and wiring and indistinguishable from factory, they'd probably never say anything about it.
I know there's an official retrofit for RSE on the F01/F02 (I have the document for that) but never saw one for the F10.
