View Poll Results: What size trailer to buy for my 07 Camry | |||
4x8' | 0 | 0% | |
5x8' | 1 | 11.11% | |
5x10' | 3 | 33.33% | |
Dont tow with your Camry! | 4 | 44.44% | |
Other - disclose in comments below | 1 | 11.11% | |
Voters: 9. You may not vote on this poll |
09-15-2019, 07:05 PM | #1 |
Rep 780
What size trailer should I buy for my DD Camry?
Long story short, ive been borrowing a small 4x8 utility trailer that i haul with my Camry, since i dont have a truck/SUV. Im in need of a trailer more and more these days and im going to pick one up but the question is, what size do i get? Ideally i would get a 5x10 but i may go with a 5x8 since my camry can only tow a couple thousand pounds. Buying a 4x8 has also crossed my mind but it can be a bit small sometimes. What do you guys think?
09-16-2019, 06:55 AM | #3 |
Hoonigan
6818
Rep 3,000
Drives: '09 328i, '98 Wrangler
Is this a V6 Camry or 4 cylinder Camry?
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
09-16-2019, 07:54 AM | #4 |
Rep 1,004
The trailer needs to be safe and sized for the loads (weight and dimensions) being carried.
The tow vehicle needs to be able to safely tow and control the trailer. So, if you’re pulling more weight than the Camry is rated to handle, you need a different tow vehicle. The smallest trailer is usually the easiest to pull and control, but it has to handle the load you’re putting on it. So I would start with the loads being carried and work forward, so to speak, to the trailer and tow vehicle. |
DPelletier675.00 |
09-16-2019, 08:15 AM | #5 |
Rep 2,873
Go big or go home - 40' duallie with onboard brakes should do the trick. You can mount the 5th wheel in the trunk where the spare tire well would be.
upstatedoc7558.50 Red Bread4463.00 |
09-18-2019, 10:43 AM | #6 |
Rep 780
09-18-2019, 10:46 AM | #8 | |
Rep 780
09-18-2019, 10:55 AM | #9 |
Rep 301
Drives: BMW M235i
Trailers can be expensive. It might be cheaper and more useful to buy a small beater truck.
09-18-2019, 10:57 AM | #10 |
Clean is the new cool, keep it that way.
808
Rep 1,685
I have a 2002 Camry 4 cylinder and it can barely move itself let alone a trailer. Don't do it, use your head.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
09-18-2019, 11:04 AM | #11 | |
Rep 301
Drives: BMW M235i
https://youtu.be/OL7KyIgXb6k |
09-18-2019, 11:07 AM | #12 |
Rep 780
09-18-2019, 11:10 AM | #14 |
Rep 780
I've already towed over a 1,000lbs with it no problem, it'll be just fine. Mine is a 2007, my old 2001 was wayyyyyy weaker. I did a 0 to 60 run with my draggy performance meter and ran 10.9 seconds in the old camry, and 8.2 in my new camry, if that doesnt tell you anything then idk what will lol
09-18-2019, 11:15 AM | #15 |
Rep 301
Drives: BMW M235i
09-18-2019, 11:18 AM | #16 | |
Rep 301
Drives: BMW M235i
09-18-2019, 11:33 AM | #17 | |
808
Rep 1,685
09-18-2019, 01:48 PM | #18 |
Rep 265
Its not so much the towing as it is the stopping and changing directions in a hurry.
The bigger the trailer the heavier it will be by itself, a decent 5' x 10' will probably be at you max tow rating before you put anything on it. |
09-18-2019, 01:57 PM | #19 |
Rep 532
5x8 is perfect for towing 2000lbs or less. I've been using one on my 1 series and honestly you barely feel it unless it's super windy, just make sure to drive defensively.
09-18-2019, 02:30 PM | #20 |
Rep 553
This. My father in law got rid of his F-150 tow vehicle used 2-3 times a year to launch his boat and we now rent from Uhaul instead. We may look like total noobs towing and launching the boat, but it was an ingenious solution.
9krpmrx8808.00 |
09-21-2019, 11:26 PM | #21 |
Rep 1,031
Drives: Like a bat out of hell.
It's not the size of the trailer but the weight. If you are buying a trailer, I would get a slightly bigger one since most state registration cost the same but I would caution not to overload the trailer with more than your transmission can handle. The wider trailer will give you the ability to haul bulkier and longer items.
If you are only hauling for short distance or on occasion, I would suggest renting from Home Depot or Menards instead. |
09-24-2019, 01:38 PM | #22 |
808
Rep 1,685
If the OP had a truck.
