07-07-2021, 01:07 AM | #1 |
Rep 115
So I've been wanting to add boost actuated exhaust cutouts to my car for a while now. I couldn't bring myself to cut up my virgin comp exhaust in case I want to go back to stock so I've been looking for another center section or full exhaust that I could experiment with. Found a full Borla cat back system for cheap on this forum so I snagged it up. $800 and local too. Next I got a pair of 3 inch ProFlow cutouts and a couple 3 inch band clamps.
07-07-2021, 01:33 AM | #3 |
Rep 115
Found the borla flange at the downpipe to be significantly less restrictive than the factory. I used a snap gauge to get down in there and take a measurement. Probably more gains in this than from having the cutouts open.
07-07-2021, 10:26 AM | #5 |
Rep 115
It's pretty rowdy. I do have downpipes on it too. I'll work on getting some sound clips up. The valves open at 5-6psi so they will start to crack really quick with how these cars make boost so fast.
07-08-2021, 09:41 AM | #7 |
Rep 115
The valves crack open quickly is what I was getting at. It doesn't take much throttle to get the valves open. I did make a bypass button that actuates a solenoid to prevent boost from getting to the valves. Mounted the button in the cigarette lighter hole in the cup holder.
TinCanSailor629.50 |
07-08-2021, 01:24 PM | #8 |
Rep 545
Props on sanitary work and thoughtful ideas. Looks outstanding!
07-08-2021, 02:09 PM | #9 |
Rep 115
07-08-2021, 07:29 PM | #10 |
Rep 538
Nice! I've wanted something like this since I got the car, but didn't even know it existed. How exactly do the solenoids function? What is involved, outside of the welding?
07-08-2021, 07:41 PM | #11 |
Rep 115
The solenoid is a simple on off valve for airflow. Most people just use a simple electronic boost controller hooked to a latching bottom or switch. I used a evap vent solenoid I had sitting around. It's nice because it only pulls 1/2 an amp. If you go to loudvalves website they have a setup you can buy. Beyond that the fabrication is a little tricky but I have a tubing contour gauge that helps a lot. It helps you transfer the shape of the pipe onto the section you are cutting in. An exhaust shop could do it for but it would be mig welded not tig.
07-09-2021, 07:30 AM | #12 |
Rep 174
Very clean install, I was considering something like this, but I would fail inspection super quick with this new Camera system we have in my state.
07-20-2021, 01:28 AM | #15 |
Rep 115
The video doesn't show how loud it really is. I need to record some better runs that I am on throttle longer. I'll try one from inside the car too.
[IMG]https://youtube.com/shorts/ZxeXiRI-p00?feature=share[/IMG] [IMG]https://youtube.com/shorts/2MEP_VKThMc?feature=share[/IMG] |
08-23-2021, 11:56 PM | #17 |
Rep 115
Thanks! It makes some wild bangs on the shifts for sure. It’s nice to be able to get violently loud at the push of a button. I went under the car the other day to make sure nothing had melted from the heat. All looks perfect. I think the turn downs direct the heat straight at the ground so it’s all good.
08-24-2021, 02:04 AM | #18 |
M5Missile1
Rep 12
That's super cool, I love that remote button!! I have cut outs also on my akrapovic evolution titanium system and it was hard to finally cut the back section.lol but it didn't come out as clean as yours cause the stainless steel cut outs can't weld to titanium without a special argon gas welder.. all slip joints with clamps ,so I titanium heat wrapped all the joints to seal from any leaks. but the sound is worth it. cheers!!
08-28-2021, 01:42 AM | #19 | |
Rep 115
09-10-2021, 02:56 AM | #20 |
M5Missile1
Rep 12
Hey there , sorry haven't been on forum due to my new build. I will post pics next week sometime when I get my car back. My ticking time bomb finally blew after 29k pretty hard miles @768whp stock internals. ill post some pics of exhaust set up with electric cut outs and new big boy build.lol
cheers!!! |
