03-02-2019, 04:48 AM | #1 |
M6 f12 Havana
124
Rep 436
Vibration at 90+mph
So when at higher speeds i have a vibration through the wheel fairly hard.. car im told gad new pads before i brought it. I had the wheels sprayed and balanced 2times now incase its tge balancing. Also just been in for tracking
Running 2.5bar all round on 20”. Any ideas? |
03-13-2019, 08:57 AM | #3 |
Rep 1,847
I had this with my car and it was the discs that were classed as warped. Only by 0.6mm but that's enough when driving to feel a vibration.
Is it smooth when you brake gently or do you feel any kind of judder |
03-21-2019, 10:31 AM | #4 |
Rep 4,209
I had the same problem and I thought it was an alignment issue. I went into the tire shop to get some new rear tires and asked them to realign the fronts thinking that was the issue. Well they showed me the front tires and the inside of the tire had wore down soo much that was flat on the inside but still a good depth on the outside of the tire. I got the front tires replaced as well and bang! no more vibration at higher speeds.
1320racer128.50 |
03-21-2019, 04:26 PM | #5 |
Rep 812
Road Force Balancing with a PROPERLY CALIBRATED machine and a tech that KNOWS how to actually use the machine and understand the readings they get. These cars are VERY SENSITIVE to any tire imbalance.
Formally known as BMWM3NYC
03-22-2019, 06:40 AM | #6 | |
Rep 19,254
03-27-2019, 09:15 AM | #7 | ||
Rep 644
1320racer128.50 |
