      03-28-2020, 12:06 AM   #859
Larry77
Drives: 2016 M5 Comp "Ultimate Pkg"
Originally Posted by CycloneVette View Post
Just bought a 2014 M5 competition package. Found out by opening the rear door that the car has M5 projector lights for illuminating the ground. Problem is, the other three doors puddle lights don't work. This is my first post so replying to activate the account so I can start a new thread asking why the other lights aren't working.
They are probably some Ebay junk, I would install some actual quality ones if I were you. Maybe these off IND? https://ind-distribution.com/collect...ctor-light-kit
      03-28-2020, 04:31 AM   #860
I'm thinking about those M5 projector lights just for the front doors.
      03-30-2020, 09:56 AM   #861
J11SEK
J11SEK's Avatar
Drives: F10 M5 2015
Before and after Re the M on front calliper.... used a vinyl transfer which isn't exactly the same size as original, but a damn site better than the faded one! New centre caps also, inline with small m badge #ocd
Ickdeep5720.50
M5Rick60123.00
OneExtra810.50
      03-30-2020, 09:58 AM   #862
SapphireM5
SapphireM5's Avatar
711
Looks great
J11SEK268.00
      03-30-2020, 10:04 AM   #863
Those larger M calliper transfers look the biz together with new hub finishers are little money for a great finish.
J11SEK268.00
      03-30-2020, 08:56 PM   #864
bbellz
bbellz's Avatar
Drives: 2018 BMW M3
More details please. My brake logos have worn off.
2018 M3
      03-30-2020, 09:25 PM   #865
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I got mine from eBay. Been on for a bit now and still look pretty good. This isn't the exact one but very similar to ones I put on https://rover.ebay.com/rover/0/0/0?m...2F383483659374
      03-30-2020, 09:26 PM   #866
bbellz
bbellz's Avatar
Drives: 2018 BMW M3
Thx
2018 M3
      04-01-2020, 11:41 AM   #867
J11SEK
J11SEK's Avatar
Drives: F10 M5 2015
Wrapped handle inserts.
After taking advice from this forum I attempted my handle wraps today.... went ok, took my time (got plenty on my hands) and wrapped the chrome inserts in gloss black vinyl wrap. Only a couple of pointers for anyone wanting to do this..... TAKE CARE on removal, the lugs on the insert are plastic and can snap with little exertion. Once removed the wrap was only tricky at the ends of the insert due to its shape, use a heat gun (or hairdryer) to ensure good adhesion. Re fitting with a thin double sided tape and they just push back into place Job done
SSJAR26.50
M5Rick60123.00
Ickdeep5720.50
Fast.F10513.50
      04-02-2020, 12:50 PM   #868
Chaman
Drives: 2015 M5 CP
Getting ready to fire up 4.6L forged motor, wrapped everything that gets hot.
R.G.233.00
Ickdeep5720.50
      04-02-2020, 01:38 PM   #869
Dwaynos
Dwaynos's Avatar
Any more pics of the build?
      04-02-2020, 04:40 PM   #870
Chaman
Drives: 2015 M5 CP
Pic 1 Dropping the stock motor.
Pic 2 moving accessories from stock motor to forged motor
Mods are :
CP piston 91mm 10:1 compression
Carillo rods
King crankshaft and rod bearing
Custom head gasket
CSF charge cooler
ProMeth methanol kit with TorqByte controller & BMS stealth tank and billet cap
Custom throttle bodies
Catless downpipes
SSP Spec X clutch kit
DSS carbon drive shaft
Bootmod3 with DME Tuning doing the mapping
After break in I will install SRM xonarotor turbo upgrade
R.G.233.00
      04-06-2020, 09:34 AM   #871
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
BMS intakes installed, it's getting a bath later today
2014 M5 6MT
Ickdeep5720.50
JW_ATL345.50
      04-06-2020, 09:59 AM   #872
nothingbutspeed
Drives: 2019 Stage 3 E85 Audi RS3
Looks good!
      04-06-2020, 12:48 PM   #873
Solo_M_Tech
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Looks good!
Thanks. had to go to Ace and get #6 machine screws for the mass air sensors but that's all.
2014 M5 6MT
      04-06-2020, 12:59 PM   #874
nothingbutspeed
Your screws inside the MAF sensor already from stock intake didn't work? That's all I used when installing them.
How is difference in sound? Any performance increase you think?
      04-06-2020, 01:18 PM   #875
Solo_M_Tech
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
na the threads in the intake are suppose to be machine screw #6. so I bought new ones. I can hear more turbo spool.
2014 M5 6MT
      04-06-2020, 06:52 PM   #876
JW_ATL
JW_ATL's Avatar
Drives: 2015 BWM M5
Nice! 😎 I added these too and the turbo spool sounds awesome.
Some of my previous cars Include current: 2015 M5 CP, 2016 GLE43, and sold: 2018 Audi SQ5, 2015 Audi Q7, 2013 AMG ML63, 2010 AMG E63, 2006 BMW 750Li, 2003 Mercedes S550, 2001 Lexus GS430
      04-07-2020, 09:59 PM   #877
Chaman
Drives: 2015 M5 CP
Wrapped turbo oil lines
Ickdeep5720.50
      04-08-2020, 05:01 AM   #878
Dwaynos
Dwaynos's Avatar
They're actually coolant lines, nice though.
      04-08-2020, 06:28 PM   #879
SapphireM5
SapphireM5's Avatar
711
How much louder is the turbo spool? I wouldnt really expect any performance gains, but I may be interested if you could hear the turbos more.
      04-08-2020, 09:53 PM   #880
Solo_M_Tech
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Nice! I added these too and the turbo spool sounds awesome.
its obvious.
2014 M5 6MT
JW_ATL345.50
