      05-04-2015, 12:22 AM   #1
VR000M5
Drives: 2015 F10 M5
Connected Drive: Bmw Online
Hey Guys
has anyone had any luck or success in getting the Connected Drive: BMW Online working?
I've managed to activate the phone bluetooth connectino for data.
The car sees the data connection but BMW online is unable to connect.
Thanks
      05-04-2015, 10:56 AM   #2
v3n0m
Drives: 2013 MCB M5
Try these settings:
HU_NBT 3003 DUN_PROFILE aktiv
HU_NBT 3003 PAN_PROFILE aktiv
HU_NBT 3003 ONLINE_BROWSER beide_aktiv
HU_NBT 3003 ONLINE_BROWSER_LIVE aktiv
HU_NBT 3003 PHONE_RSE aktiv
HU_NBT 3003 BLUETOOTH_HANDSET aktiv
The following disables telematics, which is incompatible with bluetooth tethering
HU_NBT 3003 ONLINE_SERVICES nicht_aktiv
HU_NBT 3003 ONLINE_SERVICES_GLS nicht_aktiv
HU_NBT 3003 ASSIST nicht_aktiv
HU_NBT 3003 DATACOMM_SIM nicht_aktiv
You 'may' have to set these as well:
HU_NBT 3003 BLUETOOTH_SAP_SUPPORT nicht_aktiv
HU_NBT 3003 TELEMATIC_ECU nicht_aktiv
Let me know if those work. Your menu items should change slightly after you do this in ConnectedDrive. Make sure 'Data Transfer' is enabled under both your phone configuration and in the general settings under bluetooth, and you have tethering enabled.
      05-04-2015, 10:58 AM   #3
VR000M5
Drives: 2015 F10 M5
aight man! lets give this a whirl tonight
      05-04-2015, 10:59 AM   #4
v3n0m
Drives: 2013 MCB M5
You should see: "BMW Online" and "Internet" under ConnectedDrive
"BMW Live" replaced with "BMW Online" under ConnectedDrive
      05-04-2015, 12:43 PM   #5
v3n0m
Drives: 2013 MCB M5
I'm fairly certain you have to set the telematic setting to nicht_aktiv so you might want to set that one.
      05-04-2015, 08:15 PM   #6
VR000M5
Drives: 2015 F10 M5
Hrmmmm. That didn't work. No bmw online or Bmw live now
      05-04-2015, 08:21 PM   #7
VR000M5
Drives: 2015 F10 M5
So if I disable telematric ecu. Bmw live doesn't show up.
There is an option for either. TPL or TCB as well. I tried TCB. No luck. Trying tpl
      05-04-2015, 09:15 PM   #8
v3n0m
Drives: 2013 MCB M5
Do you have a tcu option? That was default for me.
